跳转到主内容
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
143 个问题 查看全部
Is there a SATA drive in the WD Elements external HD?
I have a WD Elements 1 TB external hard drive. I would like to find out if it's a SATA drive in there, and more importantly, if I can pull this out of its external housing and put it into my computer.
The P/N is WDBAAU0010HBK-00.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Any luck? I have the same prob
完成的
添加一条评论
5个答案
已选择的解决方案
Any drive over 400GB is almost certianly SATA, you should be able to try this, as I have a 1TB MyBook, and it appears to be a standard SATA PC 3.5" drive inside, so as long as your computer has a 3.5" Bay, and a SATA connector for data, and for power, you should be good to go. This will not, however work in a laptop, they use 2.5" drives.
这个答案有帮助吗?
得分 4
2条评论:
It worked great. I have another one and I'm considering doing the same thing. Maybe I'll post a teardown with pictures to show how easy it was.
完成的
That's Great!
完成的
添加一条评论
最有帮助的答案
The WD Elements SE 2.5 external portable USB drive, however, does not. They went away with the SATA connector and have their micro USB port right on the drive inside.
这个答案有帮助吗?
得分 12
添加一条评论
Hi Nathan & Chris
i have 1TB 2.5 external HD from WD elements. the micro USB port has been damaged, hence the HD is not getting detected properly in my pc or laptop. All my data is in the HD.
Is it possible to connect this HD with anyother port. I see only the micro usb port. am not sure about other port. attached the screen shot my HD for better understanding of the internal design of HD.
if anyone can help to extract data by any means it will be helpfull.
Thanks.
这个答案有帮助吗?
得分 2
2条评论:
Hi, If people are really desperate I have a 2TB WD, apparently swapping the special memory chip with all the settings + firmware on it is feasible.
The trick is to get the exact drive and without this nothing will happen or worse the data could be unrecoverable.
Try ebay for "dead" drives sold for spares or repair?
Failing that Drivesavers are very good, and not that expensive.
完成的
I have the same problem mate .. any luck?
完成的
添加一条评论
just got one of these drives the hdd drive inside doesn't have the usual usb to sata converter that you just pull off to reveal the normal sata and power connectors of a drive that would fit into a laptop so if the micro usb gets damaged you will have no other option other than to get it looked at by a professional to repair it
这个答案有帮助吗?
得分 2
1条评论:
There is a board on the top with screws in it... the SATA plug is under it. Took me a couple years to figure that out. Lol!
完成的
添加一条评论
The statement about the elements 2.5 not having an SATA interface is false. I just bought one and tore it open because USB 2.0 is unacceptable. I now have a nive WD Caviar Green inside my PC!
I got the thing open using my fingernails and a nail clipper. It looks scary when you see the tear-down photos, but if you're gentle and take your time you can get it out without a scratch!
这个答案有帮助吗?
得分 2
6条评论:
The Element series probably has a SATA and a SATA to USB board, but I've seen the passport series have the microUSB right on the HDD.
完成的
Hi Gabe, I have WD Elements 2TB external 2.5" HDD. Since few days it working very slow. Copying and browsing folders takes too much time like USB 1.0 era. And you said this series comes with SATA to USB boards. So, I wanted to check if it has any problem in that board. Do you have any idea/images how to open it? Tried googling a lot but all videos are of WD Passport series. Not a single one found helpful. My product is this one: "https://www.flipkart.com/wd-elements-2-5...
完成的
I took my Passport appart, and the USB port is on the PCB of the HDD. There is no conversion board, the HDD is USB ONLY.
完成的
Agree with comments about passport. No SATA, only micro USB integrated into hdd circuit
完成的
You can see a video about opening these up here:
http://www.youtube.com/watch?v=mZUMh_H3B...
(not my video just found it useful).
Cheers,
Stephen
/Edit:
When opening the drive, be sure to pry all the areas labelled in the video (I broke two tabs at the back because of this - I was only wanting the drive, not the case, so not a problem in my case).
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Nathan DeWitt 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 27
过去 30 天: 77
总计 72,450
