跳转到主内容
Kindle Fire HDX 7" Micro USB Charging Port Replacement
你所需要的
  1. Kindle Fire HDX 7" Micro USB Charging Port Replacement, Speaker Bezel: 步骤 1 中的图像 1,3 Kindle Fire HDX 7" Micro USB Charging Port Replacement, Speaker Bezel: 步骤 1 中的图像 2,3 Kindle Fire HDX 7" Micro USB Charging Port Replacement, Speaker Bezel: 步骤 1 中的图像 3,3
    • Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
    • The adhesive is strong and may require an iOpener, or heat gun, to soften.
  2. Kindle Fire HDX 7" Micro USB Charging Port Replacement: 步骤 2 中的图像 1,1
    • Remove the speaker bezel.
  3. Kindle Fire HDX 7" Micro USB Charging Port Replacement, Rear Panel: 步骤 3 中的图像 1,1
    • Remove the six pink 3mm T3 Torx screws from the back case.
  4. Kindle Fire HDX 7" Micro USB Charging Port Replacement: 步骤 4 中的图像 1,2 Kindle Fire HDX 7" Micro USB Charging Port Replacement: 步骤 4 中的图像 2,2
    • Wedge opening picks around the perimeter between the display and back case.
    • Work the opening picks around the perimeter until the two halves disengage from each other.
    • Don't completely separate as the display ribbon cable still connects the two.
  5. Kindle Fire HDX 7" Micro USB Charging Port Replacement: 步骤 5 中的图像 1,1
    • Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
    • There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
  6. Kindle Fire HDX 7" Micro USB Charging Port Replacement, Micro USB Charging Port: 步骤 7 中的图像 1,1
    • Remove the four 2.3mm T5 Torx screws from the micro USB port and power button assembly.
  7. Kindle Fire HDX 7" Micro USB Charging Port Replacement: 步骤 8 中的图像 1,2 Kindle Fire HDX 7" Micro USB Charging Port Replacement: 步骤 8 中的图像 2,2
    • Pry up the ribbon cable from the rear panel with the flat end of a spudger.
    • Remove the micro USB port and power button ribbon cable.
结论
6等其他人完成本指南。
Blake Klein
于01/29/17注册
70,583 声望
创作了50篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 18
过去 30 天: 46
总计 6,488
