简介
使用本指南可以安全地从2020年末的MacBook Air(M1)上卸下和更换电池。
““为了最大程度地减少损坏的风险,请在启动此过程之前打开MacBook并让电池完全放电。”如果意外刺穿,充电的锂离子电池可能非常危险。 如果电池膨胀,请采取额外的预防措施。
此过程涉及卸下两个扬声器。你将需要新的粘合剂来正确地重新安装扬声器,以避免过度的振动或嘎嘎作响。
你所需要的
如果你的MacBook运行的是Big Sur v11.1或更高版本,则禁用自动重启可能不起作用。你可以正常进行,但是请确保在进入电池后立即断开电池连接。
使用P5驱动器卸下以下螺丝:
两颗7.9毫米螺丝
两颗7.3毫米螺丝
六颗2.6毫米螺丝
移除电池组件。
将其充电至100%,并继续充电至少2小时。
拔下电源插头并正常使用以耗尽电池电量。
当你看到电池电量不足警告时,请保存你的工作,并保持笔记本计算机处于打开状态,直到由于电池电量不足而进入睡眠状态。
至少等待5个小时,然后将笔记本电脑不间断充电至100%。
将新的替换零件与原始零件进行比较——在安装之前,你可能需要转移剩余的组件或从新零件上取下粘性衬板。
要重新组装设备,请按逆序执行上述步骤。
完成维修后,您的笔记本电脑在连接电源之前可能无法重新开机。
将您的电子垃圾带到R2或e-Stewards认证回收商。
维修没有按计划进行吗?请查看我们的论坛,以获取疑难解答帮助。
要重新组装设备,请按逆序执行上述步骤。
47等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
18条评论
You’ve gotta be kidding me…
dotmiracle - 回复
Hard to believe, but true.. this is an improvement from a couple generations ago, when you had to disassemble the entire computer or futz about with isopropyl alcohol and credit cards (or dental floss) to remove swollen but still glued in batteries. If this has you feeling overwhelmed, go look at the 74-step guide for the 2015 15” MacBook Pro Battery Replacement.
I concur with that. Made the fix for a Macbook Pro 13" 2014 some times ago and it looks really more difficult and stressing, especially with potentially destructive steps. I felt a bit lucky that it worked fine after that and since then...
Ok I have the battery out but where do you buy replacement adhesive strips? Everywhere I look they say they are for iphones or generic lcd repair. I had to take the battery out for other reasons and want to put the same battery back in.
Stephen, the linked adhesive is a generic solution & should work just fine. Apple-specific adhesives are sometimes hard to source. You could also cut and adapt stretch-release adhesive strips to fit. Best of luck on your repair!
