跳转到主内容
Samsung announced the Galaxy Flip 4 range at their "Unpacked" event on August 10, 2022. The new series of smartwatches Galaxy Watch 5 and Watch 5 Pro and the new series of Galay Buds 2 Pro were also announced.
20 个问题 查看全部
Why my phone works only when pluged in charge, and off when unpluged
my phone works when i plug it into the charger but if i unplug it emmediatelly switch off.
it looks as if i am using a laptop with no battery in it, to use the laptop i always have to plug the charger otherwise it shuts down.
thanks, inadvance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
thanks, when i plug it it starts charging
(shows the circle with 85%) when i switch it on it works, i can use it as ussual, unles i try to unplug it.
yes i have been using it almost for a year.
完成的
添加一条评论
2个答案
最有帮助的答案
It sounds like it could be a battery issue, but on a phone this new it seems unlikely that it would fail so quickly. At this point I would be trying to check the charging port first for problems; does it say it's charging when you plug it in?
How long have you had the phone? It should have at least a one year warranty, so it may be worthwhile to check with Samsung as to whether this can be repaired under warranty before you start digging into replacement parts.
这个答案有帮助吗?
得分 3
添加一条评论
I have a similar issue, but my Z Fold 4's outside screen is not working even when plugged in.
I brought it to Samsung and they are replacing the main board under warrenty.
I'd suggest you to take a backup with Samsung Switch on a PC and head over to Samsung. Not sure where you're from but in the Netherlands we have 2 years of warranty which means this is fully covered.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
peter teklu 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 37
过去 30 天: 188
总计 1,288
