跳转到主内容
华为2019年4月旗舰机,搭载6.47寸FHD+OLED屏,屏下指纹,40MP主摄,加8MP远景镜头和全新的耳机扬声器技术,型号VOG_-L29和VOG-L09
51 个问题 查看全部
No audio from bottom microphone
Hi all, I realised my P30 Pro’s bottom microphone stopped working. All apps that use this (Shazam, Google) pick up no sound from it. If I’m on a call, i have to wait between 5-10 seconds (which I think is when the top mic kicks in), then person can hear me. I have factory reset, cleared all caches but no luck so going to attempt changing the microphone/ SIM board. Has anyone done this before with success? On eb@y there are some boards that have this little silver IC in the middle of the board, and some don’t (this is on the opposites side of the SIM slot). Does anyone know what that is?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I changed bottom board with microphone and still doesnt work
完成的
添加一条评论
3个答案
最有帮助的答案
Yes same problem I had. Changing the sim/mic board will fix problem.
这个答案有帮助吗?
得分 2
添加一条评论
You're on the right track.
This is exactly what the p30 pro does when the bottom mic stops working.
The mic is soldered on a small pcb that has the simtray on it.
Do inspect your part before installing it because I’ve seen alot of them being very badly refurbished for resale where the IC and stucked there with glue instead of being soldered to the board. It might be hard to see without a microscope, but I just want to let you know that that is a common practice with the P30 pro sim/mic board for some reason.
I hope this helps.
这个答案有帮助吗?
得分 1
2条评论:
Thank you for your response. There are 2 ICs on that board, one close to the mic port and one in the centre of the board. Do you know which one it is?
完成的
I'm sorry, but I'm not sure I understand your question.
Just look at your board to see if the IC location matches what you are buying.
I think there maybe 2 version or so. That is because some countries uses dual sim, and some only uses single sim.
完成的
添加一条评论
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
theun4given1 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 92
总计 4,485
