跳转到主内容
The iOpener is an insulated, heat-retaining bag that can be heated in a microwave and used to transfer heat to the adhesive along the edge of an iPad or similar device.
23 个问题 查看全部
Is this a good alternative to an iOpener?
The kit I just ordered to change the battery to my XS Max doesn’t come with an iOpener. I can’t find it on Amazon by itself but there’s one on here by itself that I may buy. I was just wondering if I heated up a wet paper towel in the microwave, placed the warm paper towel in a zip lock bag and sealed it would that be a good alternative to an iOpener? (Or even just a warm regular towel inside a zip lock bag)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Frankly I would just use a hair dryer or heat gun (variable temp).
A wet paper towel is risky! The water could sneak in! The other factor is it doesn’t have enough heat mass.
这个答案有帮助吗?
得分 4
2条评论:
My hair dryer does an amazing job at high! It burns me.
完成的
Sounds like you need a cooler hair drier ;-}
完成的
添加一条评论
For difficult things to heat up safely, I wrap therm in a clean cup towel, turn my toaster oven on to bake and sit them on top for a couple of hours.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
TMay 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 9
过去 30 天: 47
总计 852
