跳转到主内容
The iOpener is an insulated, heat-retaining bag that can be heated in a microwave and used to transfer heat to the adhesive along the edge of an iPad or similar device.
23 个问题 查看全部
Hi, item does not get worm in 60sec
Hi,
It says that I have to heat up the iopener in 60sec but it does not get as warm as needed... I can almost hold it in my hand without it is to hot...
can I warm it in 2-3 min so that get useable?
My microwave works great...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
I thought the same thing about 60 seconds not really warming it much so I put it in for 2 minutes and it did not go so well. Do not heat it for more than 60 seconds.
这个答案有帮助吗?
得分 4
3条评论:
what happened?
完成的
Started smoking and slightly singed the microwave base. Also made me room and me stick of really badly burnt popcorn.
完成的
Had to throw the iOpener out as well because of the burned nature of the bag.
完成的
添加一条评论
Only ever microwave the iOpener for 60 seconds at at time! If you find that the iOpener isn't quite warm enough after the first microwaving, go ahead and put it back in for another 30 seconds. It should be between 160F - 190F after that, and totally usable.
这个答案有帮助吗?
得分 2
2条评论:
Do you use an iOpener? I want to know because i was looking into getting one for repairs on iphones and other phones. Wanted to know how efficient the thing is!
完成的
For me it was more effective to use heatgun... so dont throw your money away...
完成的
添加一条评论
Good old standered heat gun is the only job the I opener would never get it as warm as you need it
这个答案有帮助吗?
得分 1
添加一条评论
You only need it warm
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
vk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 1,156
