学生贡献的维基
来自我们教育项目的一支很棒的学生团队制作了这个维基页面。
SnapCam Won't Power Up
SnapCam will not power on. The power light is giving no feedback.
Faulty Charger
It is possible that the charger you are working with is faulty. To remedy this situation try another charger. The SnapCam displays a red light when it is charging.
Faulty USB Port
The SnapCam Lite will not charge on a USB 1.1 port. You should use a high speed USB 2.0 port.
SnapCam Keeps Vibrating
SnapCam vibrates without stopping, and the camera won't turn off.
Reset Required
Try pressing the reset button on the end of the camera with a paper clip or other small pointed object.
Firmware Outdated
Go to www.ioncamera.com and download the newest firmware. Then move into the firmware folder on the device.
Unreadable Memory Card
SnapCam has a memory card, but it is not reading.
Loose Memory Card
The memory card is not inserted all the way in the slot. Remove the memory card and place it back in. Push it in until a clipping sound is heard.
Corrupted Memory Card
The SnapCam Lite has restrictions in place for usable memory cards. The memory card must be a microSD card and needs to be formatted to FAT32 32KB Data Allocation. If this is the problem, the SnapCam will beep every three seconds to notify you that the memory card need to be formatted.
To format your memory card, connect it to your computer. Open up the 'Computer' window and right click on your memory card and select 'Format' in the options. In the 'Format' window, select the FAT32 32KB option and select quick format.
SnapCam Power Light Keeps Blinking Red
Power light blinks red over and over again
Incompatible Memory Card
This is yet another indicator that the memory card you are using is not compatible. You will need to find a suitable replacement. Memory Card Class 6 or above.
Blurry Pictures
All the photos come out blurry or obscured
Lens is Dirty
Try cleaning the lens gently. Use a cleaning cloth to clean the camera lens to avoid scratching it.
0条评论
