学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
If your iNNEXT N64 Classic Controller joystick moves on screen without being touched or doesn't respond accurately to input, follow this troubleshooting page for possible solutions.
Controller is Not Properly Calibrated
When the joystick is not properly calibrated, it causes erratic or inaccurate movement.
To recalibrate the controller:
- Open the control panel on Windows PC,
- Navigate to device and printers,
- Right click on controller and select Game controller Settings,
- Click properties and go to settings tab
- Select Caliberate and follow the on-screen instructions to recalibrate the joystick
On Emulator:
- Open Emulator settings
- Locate the controller configuration section.
- Calibrate the joystick within the emulator to reset its neutral position.
Driver or Software is Not Up To Date
An outdated driver can cause erratic behavior on the joystick. Ensure the controller’s drivers or the emulator you’re using is up to date. Information on how to properly update your drivers is found here.
Worn Components
- Open the controller carefully using a small screwdriver
- Inspect the joystick assembly for loose or damaged components
- Tighten any screws or replace worn out parts
- Replacement joystick modules are often available online and can be swapped in with basic soldering skills.
Here is a guide for removing the buttons
Here is another guide for removing the D-Pad
Here is another guide for removing the shoulder buttons
0条评论
