学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Pictures Are Low Quality or Blurry
When you are unable to take pictures or the pictures are of decreased quality or feature cracks.
Front-Facing Camera is Cracked or Broken
If the front-facing camera on your phone is cracked or broken, Here’s how to fix it.
Back-Facing Camera Not Functioning
If the back-facing camera on your phone is cracked or broken, Here’s how to fix it.
Applications Are Not Downloading or Opening
When you receive an error notice when downloading an app.
Sometimes when you are downloading or opening apps there are certain error messages that will appear. These error messages include 403, 492, 495, 498, 919, 921, 927, and 941. In order to find the information to fix these problems, click here.
Phone Not Turning On
When your phone will not turn on.
Phone is Not Charged
Plug phone in (make sure the charger is plugged in the wall)
Battery
If your battery is not able to charge or lacks efficiency it may need to be replaced. To do this remove the back cover of the phone by lifting the bottom left crease. Here’s how to do the rest.
Power Button
If your devices' power button is not turning on or off the phone it may need to be replaced. Here's is how to replace it.
Volume Does Not Change
When you press on the volume, the volume does not change
Volume Button
If your devices' volume button is not functioning properly it may need to be replaced. Here's is how to replace it
New Phone
When you need to move the data from your old phone to your new one.
SIM Card
If you buy a new phone and need to transfer your information over, that can be done by replacing the SIM card. To do this remove the back cover of the phone by lifting the bottom left crease. With the back of the phone facing you, on the left-hand side you will see a port and that’s where you will insert the SIM card. If you require more detailed information, click here.
一条评论
My phone cuts off on its own and heats up battery dropped when phone cuts it's self off
Daniel Boye - 回复
