跳转到主内容
dE 错误代码表示 洗衣机无法锁上机门
洗衣机显示闪烁的 dE 错误代码并发出蜂鸣声,提示机门(上开式)未关闭,但事实并非如此。这是因为小磁铁损坏或脱落了。在机门(上开式)上安装一个新的磁铁,即可触发机门已关闭的信号。
本指南将介绍如何更换丢失的磁铁(该磁铁用于向洗衣机的 CPU 发送上盖已关闭的信号)。如果没有这块小磁铁,洗衣机无法确认处于安全状态以进行洗涤,因为它会认为顶部的盖子仍然打开。
这类现代上开式洗衣机(2009 年及以后生产)似乎不再使用传统的门锁扣来锁住顶部机门,而是通过磁铁来发出机门已关闭的信号。该磁铁位于机盖的前部。当磁铁脱落时,洗衣机会提示机门仍然打开(尽管实际上已经关闭)。
当这块小磁铁从外壳中掉出(位于机盖前部下方)时,洗衣机会停止工作并显示闪烁的 dE 错误代码。这是为了安全考虑(儿童安全锁)。唯一的解决方法是找一个相同的或更强的磁铁,并将其固定在机盖上。
所需工具:
  • 磁铁
  • 强力胶带
186条评论
I Had the same problem with my LG Fully automatic washing machine
WF-T7572HS
found the magnet stuck to the wall of washing chamber.
Fixed it
My machine working perfectly fine now..
Thanks a ton...!!!
Manas Mishra - 回复 分享
hi to you,
I am Sean Silva from Sri Lanka and this web page resolved my issue and am very grateful . jsmksilva@gmail.com
sean Silva - 回复 分享
Its great, I am facing the similar but not the same problem, even the magnet is there, it is giving the beep signal showing door is open, it appears the switch is faulty, is there any thing i can do about it.
S Kumar - 回复 分享
woahhhh.. its working!!!
thanks.. no need to buy the new one.. :P
Nor Khalida Abd Kadir - 回复 分享
The magnet needs to be of suitable strength for the solution to work. :-)
Previously have tried button magnets and fridge magnets (to the extent of using single/multiple of them to boost the strength) but they were too weak to work.
Henry - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 30
过去 7 天: 180
过去 30 天: 747
总计 243,013
