学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Toshiba Satellite P855-S5312 Troubleshooting
Released June 2012, identified by model number S5312
Laptop Overheating
Computer is overheating becoming to hot
Laptop is in a High Temperature Environment
If the laptop is being exposed to direct heat try placing on a cool-flat surface with external fan blowing on the computer. If overheating proceeds follow troubleshooting below.
Faulty Fan
If you can not hear or feel a small vibration coming from the right corner (by the power button) of the computer then the fan is not operating, or if loud clicking noise occurs often the fan needs to be replaced.
CD's and/ or DVD's Will Not Play
Disk drive is not reading CD's or DVD's when inserted into the optical disc drive, they will not play.
Scratched CD or DVD
If the first or second CD or DVD does not play when inserted in the disc drive then the optical disc drive needs to be replaced.
Faulty Optical Disc Drive
If the inserted disk is not reading properly and does not sound like it is running then there is a problem with the disk drive.
My Computer
If you go to start> mycomputer>hard drive section> H-drive, and there is nothing that is label H-Drive then the entire CD drive is not working.
Faulty Display
Having trouble seeing any parts of the screen
Unresponsive Screen
If there is spotty, black display, or lines on the screen and no problem with the computer turning on then the screen is broken and needs to be replaced.
Cracked Screen
If the screen glass is shattered follow replacement guide.
Keyboard/Keys Not Responding
Keyboard not typing correctly
Faulty Keyboard
If the entire keyboard fails to respond, or when certain keys are not typing completely then try replacing it with this guide.
Keys Are Stuck In Place
When keys can't be pressed, there may be something below the physical key holding it up.
Faulty Hinge
Right and left side of the computer having trouble opening or closing.
Loose Screws
If the right or left side of the hinge is voluntarily opening most likely indicates a loose hinge.
Flimsy Screen
If the screen is falling while in use due to a worn out hinge, the hinge will need replacing.
Key Board Rising
Most of the time when any side of the keyboard is rising up on the corners of the laptop it either means part of the hinge is broken or the screws have come lose on the hinge.
一条评论
Wi-fi network don't work How can i solve it
kifle gebreyohanes - 回复
