学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Toshiba Satellite L875D-S7210 Troubleshooting
This is a guide for common problems with the Toshiba Satellite L875D-S7210. It will help you figure out the most likely reason for your issue.
Unable To Type
Some or all of the keys do not respond when pressed, or key is typing on its own
Computer Is Frozen
If your computer keys suddenly stop working, try holding down the power button for 20 seconds. Check lights to ensure computer is turned off; no lights should appear on the laptop. Press power button and wait for device to fully turn on.
Jammed Keys
For those experiencing difficulties with one key that routinely would not type, or requires excessive force, there may be debris under the key which needs to be removed. This can jam a key or break it, causing it to constantly type or not type at all. See replacement guide [无效指南链接].
Broken Keyboard
For computers which routinely have dysfunctional keys, cannot type at all, or have experienced failure after any liquid spills, the keyboard will need to be replaced, see replacement guide [无效指南链接].
Sticky Keys Is Turned On
Go to your settings and search for “sticky keys”. There will be a setting option to turn “sticky keys” off. This will stop keys from typing constantly even if they are not pressed.
Cracked/Black Screen
Screen is distorted or off even when the computer is on
Brightness Is Set Too Low
Find the display brightness button on the keyboard (often denoted with a sun with longer rays) and press multiple times to see if there is any response.
Backlight Is Broken
Shine a direct light to the screen using a flashlight and search for an image. If you are able to see an image, this means the screen is still working. The cause might be a broken backlight use the guide [无效指南链接] to fix.
Computer Is Frozen
Turn off laptop by pressing and holding down the start button for 60 seconds. Unplug the laptop and plug the laptop back in. Remove the battery from the laptop and replace the battery.
Screen Is Broken
Buy a replacement laptop screen and use the replacement guide [无效指南链接] to replace screen.
Computer Won’t Turn On
Pressing the power button repeatedly yields no response
Computer Not Charged Or Plugged In
Hold the power button for 20 seconds. Press the power button to turn on laptop as usual. If problem still persists, try disconnecting your laptop from power source and remove the battery. Hold the power button for 20 seconds, then reinstall the battery and reconnect the power cord to your laptop. Press the power button to turn on.
Faulty or Broken Power Cord
Plug in power cord. Check if charging light is on. If not, try replacing your power cord.
Faulty or Broken Battery
Make sure power cord is plugged in and charging indicator light is on. If your laptop only turns on when the power cord is plugged in, try getting a battery replacement and use the replacement guide [无效指南链接] to replace the battery.
Slow Computer Speed
Computer screen is choppy and takes a long time to respond to clicks and keystrokes
Fan is dirty
Clogged or dirty fans can cause the computer to overheat. Overheated computers will run slowly. Locate the fan slits by finding the part of the laptop which blows warm or hot air. Using a can of pressurized air, blow the pressurized air onto the fan slits. This will dislodge the dirt.
Random Access Memory (RAM) Is Faulty or Lacking
If computer is running slowly, crashes often, crashes often while browsing the web, or will not boot may suggest that you lack RAM or are using faulty RAM. See replacement guide [无效指南链接] to replace your RAM.
Motherboard Is Faulty
Constant computer freezes, frequent blue screens of death, or unexpected shutdowns are all signs of potentially failing motherboards. If you notice regular freezing during startup or while the computer has few tasks, try replacing the motherboard. See replacement guide [无效指南链接].
0条评论
