学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Toshiba Portege R835-P88 Troubleshooting
Released February 2012, model number R835-P88
bold text
Black Screen
The screen stays black when the power is on.
Faulty Battery
Check to see if the battery works with a multi-meter. Plug the battery up and see if it holds a charge. If you have a spare battery plug it up to the device. If the battery was the problem the screen should come on.
Broken Screen
If the screen itself is broken check for cracks and looseness. Dust and debris could also be inside the device keeping it from working properly.
Not Charged
The problem could be the device is not charged. Plug the power cord into a wall outlet and give it a little while to charge.
Faulty Motherboard
Turn the device off by holding the power button down for 60 seconds. Next unplug it and remove the battery. Plug the device back in and press start. If this does not work try a few times. If still not successful the motherboard may be bad.
Faulty Cooling Fan
Laptop Overheats
Laptop is overheating . Turn the device off and let it cool down for awhile. If laptop is still overheating when turned back on the cooling fan could be dirty or not working at all.
Noisy Fan
Fan becomes noisy and perhaps makes a grinding sound. Remove the fan and clean it thoroughly. If it's still making noises, replace the fan.
Broken/Defective Optical Drive
Faulty Laser
If a DVD drive refuses to read CD's but will read DVD's, or vice versa, the most likely cause is that one of the two read lasers has failed. Replace the drive.
Disc Will Not Eject
The disc will not come out of the drive when you click the eject button on the screen. Press the button on the optical disc drive itself. If it still does not slide out, make sure a program is not accessing the drive and preventing it from ejecting.
Random Access Memory Problems
The RAM is not working properly.
Slow RAM
Too many applications operating simultaneity which slows down processing. If there too many application running then check your settings and disable some programs that my activate during normal start up. You may also notice your computer going from lighting fast speed to turtle slow speed. One option to fix the issue is to clear your computer RAM. This means deleting all the stored file on the RAM which will improve your processing speed. Another option is to replace and upgrade your random access memory with a RAM that has more storage capacity.
Power Surge
Power surges also may cause RAM problem as well as any other component damage.A surge protector attempts to limit the voltage supplied to an electric device by either blocking or shorting to ground any unwanted voltages above a safe threshold.
Faulty RAM
You may notice your computer restarting during when you're in the middle of an activity, or it may freeze sporadically. It can be caused by the poor purchasing decisions of a small storage laptop. If it's slow after you purchase it, simply return it to the retailer.
For help replacing the RAM, check out our replacement guides.
Loosing Files Unexpectedly
Randomly loosing files when you restart the computer or reboot it. A simple disk check and clean can fix this.
0条评论
