学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Back Plate Removal
Back Plate must be removed to access the rest of the internal device components
Tablet Will Not Keep a Charge
Takes hours to charge but won't keep the charge for long
Faulty Battery
The battery is fried it needs to be replaced.
Faulty Charging Port
Most charging ports seem to be fragile on the tablet. The charging port may have broke or got pushed in. Often times this can effect the charging capability of the tablet, causing it to either not charge at all or only sometimes. Check to make sure the tablet is actually charging the battery or not when the power source is applied. If there is no power when plugged in then a new charging port will need to be purchased. If the tablet will only charge sometimes you may want to look at just making sure the charging port didn't get pushed in and rescuer the port.
Brightness Issues
Tablet screen is either too bright or too dim
Faulty Backlight
If the brightness appears to be too bright or too dim when turned all the way up or down, including if the brightness has been adjusted in the settings, the backlight may need replaced.
Sound is Poor
Sound from speaker is quiet.
Faulty Speaker
The speaker has been found to not work at all, or work very poorly. Sometimes it can be your own headphones that are not working, so test your headphones on another device. If your headphones are working properly, you may need to purchase a new speaker for your tablet.
Screen is Unresponsive
Screen only responds in certain places or doesn't respond at all.
Replace the Screen
Some times accidents happen and the tablet screens break or crack. There are ways to deal with this instead of just throwing it out. For example there are online shopping sites like http://www.aliexpress.com/popular/tivax-... that will send a new screen so that the owner of the tablet can put the new one on. These new screens are priced around 30 dollars, which is much cheaper than getting a new tablet.
一条评论
I was messing with the settings trying to get play store to work, I switched something and now it will go to the android screen and will just sit there and seems like its loading up but doesnt actually go to a screen where i can go into settings, How can I get it reset without being able to go into the settings? I really need help, my only tablet and I cant afford to buy another one! Help!
David Ruffle - 回复
