未列出的
这个维基不会出现在搜索结果中,但任何人都可以查看!
T23036 37" Foot Shear Troubleshooting Guide
Troubleshooting for the T23036 37" Foot Shear
Review the troubleshooting and procedures in this section to fix your machine if a problem develops. if you need replacement parts or you are unsure of your repair skills, then feel free to call our technical Support at (570) XXX-XXXX.
Symptom: Won't cut material.
Possible Causes
- Improper blade gap distance.
- Cut exceeds machine capacities
Possible Solutions
- Widen the gap to accommodate thicker gauge material.
- Make cuts within the capacity of the machine.
Symptom: Cuts aren't square.
Possible Causes
- Blade gap unequal across length.
- Too much bow in blade.
- Inadequate hold-down pressure.
- Uneven contact with guides.
Possible Solutions
- Adjust blade gap to be equal across length, follow [无效指南链接].
- Correct blade bow, follow [无效指南链接].
- Adjust gap of hold-down, follow [无效指南链接].
- Maintain consistent contact with guides.
Symptom: Poor quality of cuts, ripping, or tearing.
Possible Causes
- Dull blades.
- Poor blade gap set up.
- Loose gibs.
Possible Solutions
- Replace or sharpen blades, follow [无效指南链接].
- Adjust blade set up, follow either [无效指南链接] or [无效指南链接].
- Remove play from the gibs, follow [无效指南链接].
General Maintenance
For general maintenance information, follow the instructions in the [无效指南链接].
0条评论
