学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Camera won't turn on
No matter what you do, you can't get your Camera to turn on.
Power button may not have been held long enough
Before delving into the guts of your Camera, make sure the hold the power button.
Battery may be dead or need to be replaced
If your Camera won't turn on, try replacing the battery. You can buy a replacement battery from the SONY website.
For instructions to replace your battery click here
Blank display
It is possible that it appears nothing is happening because the display is bad. If the camera turns on but there is no display it is possible the screen is bad and must be replaced.
Motherboard may need to be replaced
If the camera turns on but there is no display then it could be a motherboard problem.
For instructions to replace your motherboard click here
Screen may need to be replaced
The screen could be broken or damaged causing a black or discolored screen.
For instructions to replace your screen click here
Camera Buttons won't work
If nothing happens when the buttons are pressed while the camera is on, the circuit board for the buttons may need to be replaced.
For instructions to replace the button circuit board click here
Camera Case is cracked
If the case for the camera is cracked and needs to be replaced, this can be following the instructions here
一条评论
my camera autometicly swich camera mode to video mode and video mode to paranoma.whiling am working on cemera .
Ravi - 回复
