无图片
这个维基缺少设备图片。请帮助 iFixit上传一张!
没有摘要
这个维基没有摘要。请帮助 iFixit编写一个 !
无类别
此页还尚未被归类。我们的管理员将很快组织并编排此内容 !
未列出的
这个维基不会出现在搜索结果中,但任何人都可以查看!
Sanyo Xacti VPC-X1200 Troubleshooting
Error
Example:
[flag|<flag id>]
Current text:
[flag|device stub]
The Sanyo VPC-X1200 is a point-and-shoot digital camera with 3x optical zoom and 12mp resolution. Models covered in this guide are the VPC-X1200EX, VPC-X1200, VPC-X1200GX.
when the power button is pressed, the camera does not show any life signs
The battery pack may be dead, inserted incorrectly, contacts on the battery and/or camera may be rusty/dirty/corroded.
The door that covers the battery/memory card may not be closed all the way. Alternatively, the switch that detects door closure may be malfunctioning.
The power LED is on and the lens is functioning, but the display does not function
The display or motherboard may have failed, requiring replacement of the respective component. Be sure that the camera is actually receiving power and isn't simply off, or that the display is switched off.
The LCD display is malfunctioning and needs to be replaced.
The flash is turned on and should fire when a picture is taken, but does not
The battery is not fully charged and cannot charge up the flash.
The flash bulb can burn out and needs to be replaced.
The error message "System Error" is displayed on the LCD continuously.
Try removing and reinserting the battery and removing and reinserting the memory card. If this does not resolve the problem, the motherboard will need to be replaced.
Using the AC adapter, the battery will not charge
The battery could be experiencing a memory effect, causing it not to charge. It could also be past it's useful life, and need to be replaced.
Be sure that the AC adapter is plugged into a functional outlet at the correct voltage. Use a multimeter to test the output voltage of the AC adapter. If there is no voltage, or it is lower than spec, the adapter needs to be replaced.
If the plug from the wall adapter does not fit snugly into the DC jack in the camera, it may need to be replaced to ensure it makes consistent contact. Also, try cleaning the battery and the charger itself with a dry cloth. This can remove any debris blocking the connection.
2条评论
my camera VPC-S880, 2 photos shows just freezes and I have to power cycle to continue using when he shoots only keeps some, Thanks in advance for any solution.
Roberto - 回复
After using zoom, the lens does not retract when camera is shut off. The infamous “SYSTEM ERROR” message shows. I tried remove and replace for the battery and SD card to no avail. Any help would be appreciated. Thanx…
Ronald Clark - NOAA Affiliate - 回复
