学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Touch Screen Will Not Work
The phone is not responding to touch.
Screen Is Dirty Or Wet
A substance coating the screen may cause the phone to be non-responsive to touch. Wipe the screen with a soft dry cloth. Microfiber cloths work well.
Phone Is Frozen
If the phone's screen is not responding to touch, resetting the phone may be the solution. Hold the power button until the screen turns black. Wait a few seconds. Hold to power button to turn the phone back on.
Phone Is Selecting Things That Weren't Selected
When you touch the phone's screen, something else is selected instead.
Phone Is Not Updated
Go to the "Settings" app on the phone. Scroll down to "System". Select "System Update". Select "Update now".
Faulty Calibration
If the phone is still making faulty selections, a factory reset may reset the calibration. Before resetting the phone, back up the phone's content on Google Cloud or a PC. To reset the phone, go to the "Settings" app. Select "Backup and Reset". Select "Factory Data Reset". Follow the prompts to complete the factory reset. Once the reset is complete, the phone will reboot.
If the reset does not work, you may need to see a technician.
Short Battery Life
The battery will not keep the phone powered for an extended amount of time.
Background Apps are Open
If the battery is draining quickly, too many apps may be open at one time. Many apps remain open, even if you switch to the phone's home screen. To close background apps, press the leftmost button on the bottom of the phone. Swipe horizontally to either side to close all open apps.
Low Storage Space
If the battery is draining quickly, this may because the storage on the phone is almost full. To clear storage space, delete unnecessary texts, emails, photos or apps.
Prolonged Phone Usage
Extensive use of the phone may drain the battery quickly. Turning on Battery saver conserves battery life during prolonged usage. To turn on this feature, select the "Settings" app. Select "Battery". Select "Battery saver".
Phone Is Overheating
The phone is getting too hot.
The Phone Is In Direct Sunlight Or Near a Heat Source
If the phone is in direct sunlight or near a heat source, it may cause the phone to overheat and malfunction. Move the phone to a cooler area to reduce its temperature.
Too Many Applications are Running
Too many open applications may cause the phone to overheat. To close background apps, press the leftmost button on the bottom of the phone. Swipe horizontally towards either side to close all open apps.
Phone Will Not Turn On
When attempting to turn the phone on, it is unresponsive.
Battery Is Dead
If the battery is dead, the phone may not turn on. Plug the phone into a charger for a short period of time before attempting to turn it on again.
Battery Is Not In the Phone
If the battery is not in the phone, the phone may not turn on. Locate the phone’s battery and make sure it is secured into the phone. Replace the back cover before attempting to turn it on again.
2条评论
Phone will not turn on
Vivek Subba - 回复
Phone will not trun on
Vivek Subba - 回复
