学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Motor spins, but Blade doesn’t Spin
The saw sounds like it is working, but the saw blade doesn’t spin.
Motor is Burnt Out
After repeated use of the saw the insulation surrounding the brush motor starts to fail. This allows voltage surges which ultimately can burn out the motor. Regular use of the saw will speed up this process. The brushes for the motor could be replaced, but if the entire motor assembly looks worn out it would be worth replacing. The entire assembly can be removed by taking apart the upper blade guard.
Output Shaft Broken
A broken output shaft would result in possible grinding noises coming from the saw. The output shaft can be replaced if the lower blade guard support is removed.
Output Gear Worn Out
A worn out output gear could result in odd sounds such as grinding or thumping. The blade could also seem to bind up constantly which would be due to the slipping in the gear. Unfortunately the only fix for this is to replace the gear which is located behind the output shaft.
Sparking from Motor
When using the saw sparks start coming out of the motor and the saw has lost some speed and power.
Worn Out Carbon Brushes
A carbon brush is a very common component to many handheld tools and get replaced very often. This is due to the fact that over time and regular use the brushes get worn down. If they are completely worn out they can cause sparks in the motor. The only solution to worn out Carbon brushes is to replace them with new carbon brushes.
Burnt Commutator
A burnt commutator can be caused by running the blade through a rough material or by trying to cut a material with a dull blade. This produces a burn or a black indentation on commutator that creates sparks in the motor when in use. One potential fix to a burnt commutator would be to use 1000 grit sandpaper and try to get rid of the burn by sanding it off. If the sandpaper doesn't get rid of the burn then you have to replace the commutator.
Loose or Wobbly Saw Blade
The blade has a noticeable wobble when it is coming to a stop and cuts are not as precise as normal.
Blade Has Deformed
Over an extended period of time, saw blades can deform due to mishandling, overuse, or heat created by friction between the blade and the material being cut. This can cause the blade to wobble, making cuts inaccurate, or excessive binding. The blade can replaced by removing the blade attachment and inserting a new one. See guide for blade replacement.
Faulty Shaft Support Bearings
If the blade is not deformed, the most likely cause for the wobble are worn bearings for the support shaft. Worn bearings can create an audible grinding when the saw is turned off or coming to a stop, as well as inaccurate cuts and binding. You can replace the bearing by removing the blade guards and blade assembly apparatus. See guide for bearing replacement.
Faulty Armature
A faulty armature or blade spindle will have very similar results as blade deformation or worn bearings. If the armature is damaged, it is recommended that a new saw be purchased.
Circular Saw Won’t Turn On
When you press the switch button, the saw doesn’t move and the motor makes no noise.
Faulty On/Off Switch
This switch turns the motor on and off. The switch should be replaced if it does not activate the motor when when the safety key is inserted. You can also test your old switch using a multimeter. If you hear the tone on the multimeter, your switch is not broken. If you do not hear the tone, you should replace your old switch with a new switch.
Faulty Power Supply Cord
Look at the power supply cord for disconnected wires or damage. If there are any loose power cord wires, reconnect them.If it is damaged, replace the power cord. If it is necessary to replace the power supply cord, this must be done by the manufacturer in order to avoid safety hazard.
Blade Lock Doesn’t Work
The blade lock does not stay secure when it’s engaged.
Blade Lock Spring Damaged
After some time due to excess of use, the lock might lose its grip. The lock can also be damaged if it was engaged while the blade was still on . To prevent damage to the spindle or spindle lock, always allow motor to come to a complete stop before engaging spindle lock.
Unfit Blade Saw
An unfit blade will not enable a lock to fit and grip it as it should. There are many different models of rigid circular saws. For example the model R3205. The only fit blade is 7 ¼ in. You have to make sure you know which model you have and get the right blade fit.
0条评论
