学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Motor is smoking or sparking
Smoke or sparks are coming out of the motor housing while grinder is in use.
Old or damaged carbon brushes
The carbon brushes should wear down evenly over time and be replaced, but the brushes can also become damaged during use. If carbon brushes are worn down or have chips, they must be replaced. If a burr has formed, the brush may be removed and the burr carefully filed. To access, remove, and replace the carbon brushes, see our guide here.
Debris in carbon brush housing
A buildup of debris around the carbon brushes can prevent them from moving up and down properly and disrupt their ability to supply current causing sparking and/or smoking. To visually inspect the brush housing for debris, see how to access the carbon brushes here.
Inoperable buttons and switches
Buttons on the grinder won’t press or release.
Safety and rotation switch springs are faulty
If safety switch fails to release after being depressed, do not attempt to use the device further. The springs for the button in question may be old or faulty. Keep your fingers away from the trigger and make sure there is no power to the device. If safety switch refuses to depress, the device will not operate and will need to be disassembled to assess the issue and possible to replace the spring. In either case unplug the device for safety.
Power button spring or internal component needs replacement
If the button is able to be pressed and the tool is not responding, make sure there is a power source to the device. If that is not the issue the button itself, or an internal component might need replacement. If the button itself is jammed and will not go down, there might be a build-up of dust, metal, etc, between the button and the body of the tool. If possible take a small household object to scrape the debris out. If this does not resolve the problem with the button, an internal component might need replacement.
Grinder disk is loose
Grinder disk does not operate smoothly.
Grinder is insufficiently tightened
Use the provided wrench to tighten down the grinder blade. The bolts attaching the blade to the motor might need to be tightened down. If the blade is not flat, you will need to return/purchase a new grinder blade.
Central motor axis is not properly fitted
Check the fittings between the disk itself and the central motor axis as a snug fit is needed to keep a flat grinding surface. If this does not fix the problem, see Grinder is insufficiently tightened above for additional solutions.
0条评论
