学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Tablet will not power on
The tablet shows no response and no signs of powering on.
Faulty Battery
If the tablet is able to power on only while plugged into the power adapter, then it is likely that there is a faulty battery. Follow this guide to replace the battery.
Faulty Charging Port
If the charger needs to be held at a certain angle for it to work, then it is likely that the charging port needs to be fixed because it is loose. If the problem continues without replacement, it can burn. Try using a different charging cable.
Faulty Motherboard
If you don’t see any response while charging, powering the device, or replacing the screen, the only possible component left to replace is the motherboard. Follow this guide to replace the motherboard.
Tablet will not connect to the internet
The tablet cannot find an active wireless signal.
Faulty Antenna
If your tablet is unable to find a WiFi connection, it is possible that you have a faulty antenna. Follow this guide to replac the antenna.
Distorted Display
There is a defect with the screen making it distorted.
Cracked Screen
Take off the backplate of the device. On the right side of the device is a cable that looks like a ribbon. Unplug the ribbon cable and remove the display for the chassis of the device. Take the new display and thread the ribbon through the hole and plug it in. Snap the new display into place and put the backplate onto the device. Power on the device.
No Screen Lighting
Take off the backplate of the device. Identify the ribbon cable on the right side of the device. Check to see that all pins are linked to the connector and that it is plugged in completely. If it is plugged in and still not producing light, the display must be replaced. Unplug the ribbon cable and remove the display for the chassis of the device. Take the new display and thread the ribbon through the hole and plug it in. Snap the new display into place and put the backplate onto the device. Power on the device.
24条评论
mine comes on but only shows battery life at 100% then turns off again
Beth Martinez - 回复
Mine will not boot past Viking Pro10 screen, please help…
Walter Cwiek - 回复
Google play has stopped
Sherry Ryan -
Mine will turn on but wont turn on all the way it hits the viking pro 10 screen an just stop
Garret A - 回复
Okay we have the same problem with the screen going to Viking Pro 10 and thats it!! Well what is the answer to repair or fix this??????
Sherry
sherashley - 回复
