存根页
This wiki page is a stub. Help us improve this page by adding information to it!
学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Controller will not turn on
The controller doesn’t power on when adapter is connected
Controller's USB plug was damaged
Faulty USB may not allow for the controller to power on. In order to fix this you may replace the broken USB by plugging in the new USB.
Game not registering input
When values are inputted into the controller, the game doesn't respond
The Controller’s left thumbstick will not click
When the controller is powered on the thumbstick will not register input when pressed. This may be caused by trapped dirt in the sensor. To fix this, remove the backing of the controller and take off the joystick cover and clean the sensor or replace the sensor if it is damaged.
Multifunctional wheel’s will not click
When the controller is powered on, the multifunctional wheel will not register input when pressed, in any direction. This problem could be due to the accumulation of dust and dirt in the crevices of the controller, worn plastic, and damaged electrical sensors beneath the buttons. To prevent this problem, keep the controller in good condition, and clean every once in a while. To fix this check buttons as well as sensors, and fix accordingly.
Replace A,B,X,Y buttons
The A,B,X, and Y buttons are faulty. The buttons are designed to smoothly click down to trigger an action within the game. The faulty buttons could be due to the accumulation of dust and dirt in the crevices of the controller, worn plastic, and damaged electrical sensors beneath the buttons. To prevent this problem, keep the controller in good condition, and clean every once in a while. To fix this check buttons as well as sensors, and fix accordingly.
Game registering input without input
Involuntary input movement on game
Stick drift
In order to prevent this you must take apart the casing of the controller by removing the bolts on the back of the controller. After doing so we must get an electronic cleaning solution to clean the joystick sensors. Then reinstall the case.
一条评论
Thanks! Hold on to the fact that you need a custom therapy help service among us and don't tell anyone. Let your professor think that you are the author of all therapys and calmerry therapys. It's safer and helps avoid awkward questions.
Doug Warner - 回复
