学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Shorter than expected battery life
The DMC-G7 is rated for 350-360 still shots per full charge. If you find the battery is performing notably worse than this…
Battery not fully charged
Ensure the battery has fully charged. The original Panasonic charger will change the status LED to green when the battery has completed charging.
Battery is old
Consider the age of the battery. Lithium-ion batteries can only go through so many recharge – discharge cycles (approximately 500-1500 depending on various factors such as temperature, storage conditions etc.). If the battery is over 5 years old, it is possible the battery is reaching the end of its useful life and should be replaced.
SD card not detected
When you plug in the SD card the camera does not detect it properly or does not respond at all…
Memory card formatted incorrectly
Attempt to reformat the SD card using the camera’s formatting tool. To format the SD card, follow this guide.
Dirt on card or in card slot
Ensure SD card pins are clean (free of debris and gunk). Ensure slot is free of dust using compressed air (do NOT blow with mouth into the slot: moisture from breath could cause more damage.)
SD card lock tab engaged
It is possible the SD card lock tab has been moved if the SD card has been removed and reinserted several times.
Video fails to record to memory card
Camera randomly stops recording data to card or gives card write error…
Recording time limit exceeded
The Panasonic Lumix G7 can only record continuous video for 30 minutes or 4GB. The video normally rolls over, automatically creating new files. If recording completely stops after 4GB or 30 minutes, reformat the memory card.
Memory card not fast enough
It is possible the current memory card is not fast enough. When recording 4K video, the camera can write at speeds up to 100MB/s. 4K video recording requires at least a UHS-3 memory card. Make sure the card used is at least UHS-3. Some SD cards advertise greater read/write speeds than they can actually maintain. Try using a different SD card.
Broken memory card
Defective memory cards may operate at reduced transfer speeds or not accept written data at all. Try using a different SD card. If the second card works, reformat the broken card. If reformatting does not resolve the issue, replace the card.
Flash not working
The internal flash does not emit light when taking pictures.
Flash arm not deployed
The flash cannot operate until it pops up. Press the flash open button to the immediate left of the electronic viewfinder.
Shutter set to silent mode
The flash is disabled in silent shutter mode. Go into settings and turn off silent shutter to re-enable flash operation.
Flash fuse is broken
The flash PCB contains two fuses. These fuses may occasionally blow. Access the PCB and use a multimeter to check for continuity on each fuse. Visit the flash fuse replacement guide to learn how to replace the fuses.
Flash capacitor is broken
If the flash capacitor fails, it will no longer build up the energy to flash. Check the flash capacitor value using an ESR meter. Visit the flash capacitor replacement guide to learn how to check and replace the capacitor.
The camera does not start
When flipping the power switch the camera does not boot…
Battery is depleted
The battery may be depleted. Plug your battery into a wall charger to charge up your battery.
Battery contacts are dirty
The battery contacts could be dirty preventing the battery from making a complete connection with the camera. Clean the metal contacts using 90%+ isopropyl alcohol or blow out any dust using compressed air.
Camera needs a power cycle
The camera may not fully reset until all components have discharged. In order to ensure that all components have discharged, a power cycle is required. To power cycle the camera: pull out the battery, flip the power switch to the on position for at least 10 seconds, flip it back to the off position and reinsert the battery before attempting to boot again.
Battery charger is damaged
The charger for the battery could be damaged. Ensure the status light is on when the battery is in the charger and the charger is plugged into the wall.
The camera does not connect to WiFi
The camera does not connect to a wireless network, or other devices will not connect to the camera’s wireless network…
Mobile operating system out of date
If the camera has trouble connecting to phones/tablets, ensure that the version of iOS or Android supports the corresponding application (iOS 6.0 and Android 4.0). In addition ensure that the application installed is the appropriate application for your device and is up to date.
TV not in DLNA mode
If the camera has trouble connecting to a TV, ensure the TV supports the Digital Media Renderer function of DLNA and that the TV is in DLNA mode.
Printer not connecting
If the camera has trouble connecting to a printer, ensure the printer supports PictBridge and is compliant with DPS over IP.
AV device not connecting
If the camera has trouble connecting to an AV device, ensure that the device supports the DLNA standard and is in DLNA mode.
Windows computer not connecting
If the camera has trouble connecting to a Windows computer, ensure that the user account only contains alphanumeric characters and that the folder to which the files will be sent has sharing enabled. Check to see if the computer’s workgroup is set to the default of “WORKGROUP”. If the workgroup is not the default, then, in the PC connection section of the camera’s WiFi settings, change the workgroup setting to match the computer’s workgroup.
8条评论
I am having trouble with the film editing on my computer. The videos look laggy and are glitching when I look at them on my computer. but look fine straight on the camera. Why is that how do I make it go to a normal speed! Please help
Kay Suzz - 回复
Hi Kay,
I’m one of the students who wrote this guide last year, I can think of a couple reasons for this.
1) The speed of the SD card reader on your computer may not be able to keep up with the required data rates. I would recommend copying all video files from the SD card onto your computer before doing any editing and working with those copied files.
2) 4k video can be quite taxing for older computers (my mother’s 2013 Mac Book Pro for instance cannot reliably play them at full speed) and so it could just be the computer hardware is not up to the task.
Alan Gardner -
Hi for some reason when pick the resolution of my camera 16MP,8MP,4MP the camera usually crops the image when set to 8MP or 4MP. In my case, the camera is not cropping at these resolutions I have even tried resetting my settings multiple times. My digital zoom for 2x and 4x seems to be working fine though..
Abjayan - 回复
Having problem we’re all my pictures say raw on them and I can’t figure how to get the raw off pictures
Robby Hottel - 回复
Hi, I shot a photo with my camera and the camera got black, I removed the lens and found out that a black stuff has covered the mirror. Please what do I do?
JOMO TV ONLINE (Jomotv) - 回复
