学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Camera Will Not Power On
The camera will not respond or show any sign of turning on.
Charging Camera
To charge your camera, plug the USB is connector into to your computer or other USB enabled device. If the camera still does not turn on, check to make sure there is a battery in the camera. If there is a battery, wait at least 30 minutes for the camera battery to charge. If after 30 minutes of charge and the camera still will not power on, consider replacing the battery.
Replacing Battery
Please see Battery Replacement repair guide. If you exchange the old battery for a new one, and the camera still will not turn on, consider sending back to Olympus or contacting Olympus Customer Support. (Note: This is an external link that will take you directly to Olympus Customer Support webpage.)
Device Is Failing to Charge
The camera is connected to the computer or other USB enabled device through the USB cable given with the camera, but the camera is failing to charge.
USB Connection
Make sure the USB connector is connected to both the camera and the computer or USB enabled device. If device still doesn't charge, check to make sure there is a battery. If there is a battery, replace old battery with new one. See Battery Replacement guide.
Maintaining Waterproof Capability of Camera
The camera is not behaving as expected after going under water.
Depth of Camera
The camera can be taken up to 33 feet underwater. Taking the camera deeper than this will increase the risk of having water break the seals within the camera, causing damage to the camera.
Locking Battery Compartment
Make sure the battery compartment is completely shut and locked before taking the camera underwater. If the camera is not completely sealed, water will leak in and cause damage to the camera. See Locking Mechanism repair guide to ensure battery compartment is locked.
Drying Out Camera
After using the camera in water, you will need to dry out the camera. First, turn off camera then open up the battery compartment and take out the battery. Once the battery is outside of the camera, leave the camera open and store in a dry space to air out.
LCD Screen Is Unresponsive
The camera is on, but the LCD screen is unresponsive.
Reboot Camera
Turn off the camera by holding the on/off switch on the top of the camera for 10 seconds. Once the LCD screen has turned black then press the on/off switch again to turn the camera back on.
Replacing the LCD Screen
If the LCD screen still isn't working properly, see LCD screen repair guide.
Flash Does Not Work Properly
The flash does not turn on when enabled on the camera.
Verifying Flash Setting
Make sure your camera is not in "Auto Flash" mode as sometimes this will not enable the flash. Verify you have selected the "Flash" setting, which looks like a lightning bolt, in order for the flash to absolutely occur.
Rebooting Camera
If it is on the flash setting and still not working, reboot the camera by holding the on/off switch on the top of the camera for 10 seconds.
0条评论
