Student-Contributed Wiki
学生贡献的维基
一名我们训练的优秀学生制作了这个维基。它不是由iFixit的工作人员进行管理的。
Nikon Coolpix S8000 Troubleshooting
No matter what you do the camera won't turn on.
After exhausting all options, open flap to remove battery. This battery can be found in any store where there is an available electronic section.
First remove the battery to make sure that it is inserted correctly. Next, charge the camera to make sure the battery is charged and there is not a short in it. After charging the camera, power it on, if the camera does not power on, the next step would be to replace the battery.
"There is no light present on the screen when power button is pressed.''
Once noticing the screen is black, make sure the on/off button is pressed to turn on the camera. If there is still no light or picture, your battery probably needs to be charged. After letting it charge for a bit, press the on/ off again.
== Picture Distortion==
"When camera is on, the picture is out of proportion or distorted.''
First, play with the zoom feature on the camera to find the best quality picture. Next, you may want to clear the lens in the front of the camera of any smudges or dust with a small, glass-cleaning towel. Also make sure the lens is free of any cracks. Then, while preparing to take a picture, make sure the lens cap opens.
"The camera won't allow pictures to be taken.''
First, go through your camera’s photo album to see if your camera is at capacity. If it is, deleting old pictures would be a quick fix to clear up memory and allow pictures to be taken. *To create more memory and reduce the likelihood of pictures having to be deleted, obtain a memory card and insert it in the bottom of the camera, by the battery.
" There is no flash when trying to take a picture.''
First, recognize that the flash is supposed to pop up when taking a picture. If there is still no flash, make sure the flash is enabled, test the flash by taking a picture. If it still does not work, gently pull up on the flash to make sure nothing is jammed that would prevent it from popping up.
0条评论
浏览统计数据:
过去的24小时: 1
过去的7天: 7
过去的30天: 22
总计 1,688
