学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Camera won't turn on
After pressing the power button the camera does not turn on.
Batteries are either defective or dead
Replace the batteries with any Lithium AA batteries. If the device still will not turn on, it will need a more delicate procedure.
Power button is jammed
If there is no click when pressing the power button or the power button seems to be stuck in, the power button is jammed and needs replaced.
Replace the batteries with any Lithium AA batteries. If the flash still will not work, it will need a more delicate procedure.
The flash doesn't work
With the flash setting on there is no light coming from the flash.
Buttons do not work
Some or all of the buttons on the front do not respond when pressed. This is problem with control panel, and it needs to be replaced.
The Flash is turned off or not open
To turn on the flash it must be opened up. The switch to open the flash is on the front of the camera. Push the switch and it will automatically turn the flash on. IF that does not resolve the issue in the menu screen there will be and option to turn the flash on.
Bulb is broken
After replacing or checking the batteries, your issue may be the bulb. If it is broken or damaged, replace the bulb following this guide
Screen wont show an image
The camera power light is turned on although the screen isn't displaying an image.
Replace the batteries with any Lithium AA batteries. If the screen still will not turn on, it will need a more delicate procedure.
The LCD screen is broken
If your screen is cracked or was dropped, the screen may not work properly. This problem could come form the screen or from where the screen connects to the motherboard. Follow this guide of how to replace it.
Lens errors
My camera says lens error on the LCD screen
Cannot get the zoom to work
Zoom does not work
If when turning the zoom ring, the lens does not react. The zoom ring may be broken and need to be replaced.
Jammed Lens
The camera turns on and when the lens makes an attempt to extend, due to a possible mechanical problem the lens error appears on the screen. The lens should be replaced following the guide.
Broken Lens
If when pressing the zoom button, the lens does not react. The lens maybe be broke. If this is the issue, it needs to be replaced by following the guide.
Can not record videos or take pictures
After taking a video, I cannot find it saved.
Camera require a memory card
There must be a place to store the data so check to make sure there is a memory card in the device, it will be located under the right side of the camera.
Camera says card is write protected
On most SD cards there is a switch that will protect that SD card from having data placed on it. This switch needs to be in the write position. Switch the write-lock switch to the write position
Storage maybe be full
If the storage is full there is no more space to save the files. Connect to a computer to remove the files off of the device. You can use either a micro-USB cord or remove the SD card and connect it to your computer.
Batteries Exhausted
First make sure you have new batteries in the device. If you do have new batteries in the device, this error may occur if the battery door gets loose. It can be resolved by keeping pressure on the bottom side of the camera where the battery door is located.
6条评论
Camera went off by itself with the lense extended. Now it's stuck. how can I fix it? Any one to help?
Thomas Antony - 回复
my camera is coolpix P610 and the camera don't turn on. What I have to do???
please answer
Shahad Mustafawi - 回复
This happened to me too! How'd you fix it?
Liah Alemayehu -
Hi My Coolpix 610 won't load pics to the PC anymore. Tried different cable, port and loading ViewNX2 but no good, afterr plugging into a USB port, the 'onlight' comes on, after a minute blinks a few times and then turns off - any ideas?
Mike Frost - 回复
Can someone help me? My Coolpix P610 will not take pics and wont record videos.
the screen is on and the displays like the battery life, and stuff like that show but the rest of the screen is black. with the viewfinder and the monitor I can not see what I am looking at.
coyotekelly - 回复
