学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Faulty Touchpad
The touchpad is sometimes unresponsive.
Touchpad may be dirty
Once the touchpad gets dirty it may seem less responsive. The touchpad may only be covered and can easily be cleaned off to fix this issue.
Short Battery Life
The battery life is short so the laptop will power off soon without a charge.
Faulty Power Adapter
Make sure the power adapter is plugged in and that the light is on. If the light is not on while the power adapter is plugged in, the power adapter is faulty.
Faulty Battery
Plug in power adapter and make sure the light on the power adapter is on. If the computer only turns on with the power adapter connected to it regardless of how long you charged it, then the battery is faulty and you should replace the battery.
Aged Battery
The battery has a certain amount of power it can store and over time this amount can decrease. The easiest fix to this problem would be to replace the battery with a new one.
CP moving slowly
The CP will often take more time to do simple task.
Not Enough RAM
When there are too many things such as documents and programs, the laptop might work slower than the usual. You will probably need to delete some old files that are no longer in use.
Frequent Overheating
The laptop will overheat and possibly shut off or freeze.
Fan overheats
If fan is getting too hot or not working the fan may possibly be overworking itself and is not strong enough for the laptop. In order to fix this a new fan must be installed.
Dirty fan
Once the fan gets dirty it may seem less responsive. A quick clean will speed up the fan making it work faster.
Hot area
If you are using your laptop outside, the sun might affect the laptop’s fan. It will probably make the laptop hotter and cause the fan to work harder. To fix this, taking the laptop to a cooler area should help.
Screen Black
Plugging in the power supply and powering on, the Green LED turns on at the power button and the keyboard backlight flashes once and sounds like the fan is turning. The Fn LED flashes once green and stays green for about 4 seconds and then stays off. The red LED on the top of the screen “I” in Thinkpad stays lit red and/or red LED on the top of the screen “I” in Thinkpad blinks red 3 times when plugging in the power supply and not even powering on or doing anything else.
LCD connector not seated
Verify the LCD connector is seated evenly and entirely so all pins have good contact. https://www.youtube.com/watch?v=vsoj4ehQ...
一条评论
my lenovo thinkpad x240 does’t boot instead beeps
elviskome - 回复
