Boombox has no power
No display, no audio...nothing is happening.
Power cord is unplugged
This may sound simple, but always check this first. Even if you think it's plugged in, check to make sure the plug isn't sticking out from the outlet at all. If it is plugged into a power strip, make sure the strip is on.
Power switch is off
On the back face of the device towards the right there is a switch that slides left and right controlling the power. Make sure this switch is in the "on" position.
Batteries are dead
This cd player has an option for using batteries to power the device. One bad battery can prevent the player from turning on. Find and replace the bad batteries using the Battery Replacement Guide.
CD won't play
The device has power, but when you put a CD into the tray no sound will come out.
Volume is off
The CD could be playing without you even knowing if the volume is too low. On the front face of the device there is a button marked "Volume". Use this to increase the volume.
CD deck has moisture
If there is any kind of moisture in the CD loading area it will keep the CD from playing. Even if there is no visible moisture, remove the CD and leave the tray open for about an hour to dry.
CD is broken/dirty
The issue may not be with your music player at all, it may be the CD. Try playing a different CD. If this works, you know where the problem is. This can be fixed easily by cleaning the CD. If the problem persists, the CD may not be repairable.
Laser is broken
If nothing else works, the laser reading the CD is probably broken. Refer to the Laser Replacement Guide for instructions on how to fix this.
Radio won't play
The device has power, but when you try to listen to the radio no sound will come out.
Volume is off
The radio could be playing without you even knowing if the volume is too low. On the front face of the device there is a button marked "Volume". Use this to increase the volume.
Radio is tuned incorrectly
The radio must be set to the correct station in order to pick up to signal. Even if you are tuned to the station you want to listen to, it is possible that station has quit broadcasting. Try searching through the other frequencies to see if you pick up any other signals.
Antennae is broken
If the antennae is broken, the radio will be unable to pick up any signals or the signal will be very weak. Refer to the Antennae Replacement Guide for instructions on how to fix this.
CD skips
The CD will play, but after a certain amount of time the audio will jump around or quit altogether.
CD is broken/dirty
If the CD is scratched or damaged, it will reach a specific point and skip frequently or get stuck in this spot. This can be fixed easily by cleaning the CD. If the problem persists, the CD may not be repairable.
Lens is dirty
The laser that reads the CD is focused using a lens. If this lens is dirty or broken, the laser won't read the CD properly and could results in skipping. Refer to the Internal Component Disassembly Guide to reach the lens. Use a polyester cloth to wipe the lens clean.
Traverse Assembly is broken
The traverse assembly controls the path the laser travels along to read the CD. If this is dirty or broken the CD will skip frequently or get stuck in one spot at random. Take your device into a professional to have this replaced.
Buttons won't work
Everything works on the device until you try to press one of the buttons on the front face and nothing happens.
Buttons are unresponsive
If there appears no physical damage to the buttons, they may have lost their connection to the operating system. Many times, this can be fixed by restarting the phone. Press and hold the power button to turn the phone off, then press and hold again to turn it back on.
Buttons are broken
If there is physical damage to the buttons or nothing else seems to work, the buttons that aren't working probably need to be replaced. Refer to the Button Replacement Guide for instructions on how to do this.
Next/Previous track buttons aren't working
If your issue is specifically with the "Next Track" or "Previous Track" buttons, the problem is probably internal. Refer to the troubleshooting section "CD Skips" and follow those instructions.
一条评论
My portable Insignia CD player; about 5 years old, wouldnt work. Installed new batteries, inserted correctly. When I pressed play. The readout displayed “hold “ then displayed “good bye”. Should I just buy another or is there a fix?
nanny1934 - 回复
