学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Tablet Will Not Power On
No matter what you do, you can not turn your tablet on.
Broken Charger
Make sure your charger is plugged in, if it still will not power on, your charger is broken. Consider purchasing a new charger
Battery will not hold charge
If your tablet powers off when the charger is removed your battery needs replacement. Replace the battery using this guide.
Camera Problems
No matter what you do, you can not get your camera to work.
Image is cloudy or distorted
Check to make sure the camera is not being blocked by the case or other objects. Clean the lens of the camera to remove any dirt or smudges.
Image will not appear
Open the camera app, if the picture does not appear, try using another app to start the camera. If the camera still doesn’t show a picture, your camera needs replacement. Replace the camera using this guide.
Problems with sound
No matter what you do, you can not get the audio to work.
Sound is very low
Put your ear close to the speaker openings and see if both speakers have sound coming out of them. If only one is producing sound then replace the broken one using this guide.
No sound from device
Check to make sure that the volume is not turned all the way down.
Check to see that the “in app” volume is not set to the lowest setting. Some apps have their own specific volume controls.
Try using earphones if the sound works through the earphones but not when you unplug them then the speakers are bad. Replace the speakers using this guide.
Sound is distorted
Check to make sure the device and/or in-app volume are not turned too high.
Also make the actual device speaker is not contaminated. Stray objects can become lodged in the speaker and cause a buzz like sound distortion.
Screen
No matter what you do, your screen will not work.
Screen is black
If the screen is black and you know that the device is turned on, make sure it is not in sleep mode. If the screen is still black, it needs replaced using this guide.
Screen is cracked
If there is a crack in the screen then it needs to be replaced using this guide.
Motherboard
Whatever you do, you just can not get the tablet to work.
Device wont power on
If after replacing the battery the tablet still will not power on, there is probably something wrong with the motherboard. Replace it using this guide.
Screen is frozen
If the screen is frozen and restarting the device does not fix the problem, the motherboard may be defective. To fix this you may need to replace the motherboard using this guide.
Device will not connect to internet
The wireless receiver may be defective if you cannot connect to find/connect to any internet signals. To fix this you need to replace the motherboard using this guide.
一条评论
The 1mobile app won’t load, so I can’t download games
Simon Roballo - 回复
