学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Garmin will not turn on
Faulty Battery
check battery meter or plug device in to charge.
Faulty Screen
See the LCD Touch Screen Replacement Guide.
Battery is not charging
Poor charging cable connection
Remove charging cable and re-insert into the back of the devise firmly.
Faulty Battery
The battery may be faulty. Replace the battery.
Poor or no audio
- Speaker is obstructed. Check that the speaker has not come loose in the housing using the Speaker Replacement Guide.
- Faulty speaker or poor connection. Replace the speaker.
LCD touch screen is not responsive
- Battery is not charged - Remove charging cable and re-insert into the back of the devise firmly.
- Faulty Screen. See the LCD Touch Screen Replacement Guide.
Screen is not displaying anything
- Loose screen connection.
- Broken screen.
Technical Difficulties are not solved after checking above recommendations
- The motherboard may be faulty. Replace the motherboard.
6条评论
What size screw is used on the back? It's appears to be an Allen-sized head but is larger than 1.2 but smaller than 1.6 Allen wrench. The HDMI connector requires re-sodering as it's loose and won't connect with the cord, thus not powering up or being to use it.
Glenn D Griffin - 回复
Those are very small torx screws. Try a T-5.
Dick Tracy -
Batterie not charging cause thé câble inside lighter have a fiuse broient whow can get onde or find one. I an fromage montréal Canada
boily.guy - 回复
Fiuse broken
boily.guy - 回复
Nuvi 2555 fiuse broken on câble charging on car lighter tell me whow can i get one Thanatos you
boily.guy - 回复
