学生贡献的维基
来自我们教育项目的一支很棒的学生团队制作了这个维基页面。
Garmin Nuvi 2589LMT Troubleshooting
Battery Drains Quickly
The battery of your GPS drains faster than desired.
Screen Brightness
Decreasing the screen brightness will increase battery life. To adjust the screen brightness, go to Settings > Display > Brightness.
Screen Timeout
Decreasing the time before the GPS enters sleep mode will increase battery life. To change the screen timeout, go to Settings > Display > Display Timeout.
Volume Level
Decreasing the volume level will increase battery life. To change the volume, go to Volume and decrease the volume using the slider bar.
Bluetooth Left On
Turning Bluetooth off will increase battery life. To turn Bluetooth off, go to Settings > Bluetooth.
Sleep Mode
Putting the GPS in sleep mode when not in use will increase battery life while keeping it ready for instant use. To put the GPS in sleep mode, press the power button on the back of the device.
GPS Left On When Not in Use
Turning off the GPS when you are not going to use it for an extended period of time will increase battery life. To turn off the GPS, hold the power button until a prompt appears on the screen and select “Off”.
Faulty Battery
If none of the above solutions resolve the battery issue, the battery may be faulty or worn out. Replace the battery using this guide.
Battery Will Not Stay in Place
The battery in your device keeps falling out.
Worn Out Adhesive
Inspect the underside of the battery for the adhesive strip that secures the battery. If the adhesive strip is old or worn out, you will need to replace it.
Incorrectly Positioned Battery
Ensure that the battery is positioned right side up, with the adhesive strip down. Press the battery firmly into place. The battery wires should be in the corner closest to the motherboard.
Car Charger Does Not Charge Device
The device will not charge in your vehicle.
Vehicle Not On
Confirm that the vehicle is turned on and is supplying power to the power outlet.
Improper Operating Temperature
Check that the interior temperature of the vehicle is between 32°F and 113°F (0°C and 45°C).
Burnt Out Power Cable Fuse
Check the fuse in the vehicle power cable; it may be burnt out and need to be replaced.
Burnt Out Vehicle Power Outlet Fuse
Check the fuse in the vehicle power outlet; it may be burnt out.
Suction Cup Does Not Stay On Windshield
The suction cup on the GPS mount continuously falls off of your car's windshield.
Dirty Suction Cup and/or Windshield
Clean the suction cup and windshield with rubbing alcohol. Dry suction cup and windshield with a clean, dry cloth. Mount the suction cup.
Screen Will Not Turn On
When you turn the device on, the screen is not showing anything.
Device Not Charged
Charge your device for 4-5 hours to ensure a full charge. If it still does not turn on, the screen may be damaged or disconnected or the battery may not be working properly.
Screen May Be Damaged
The screen has cracks or punctures that may prevent it from turning on and needs to be replaced. See a step-by-step guide for replacing the screen here.
Severed Connection
The screen has disconnected from the motherboard and must be reattached. See a step-by-step guide for replacing the screen here.
Device Will Not Turn On
When you press the power button, the GPS will not turn on.
GPS is Not Charged
The battery in the GPS will need to be charged often. Make sure the device is fully charged before use.
Charger is Defective
Check to see if the charger is working properly. The charger may be tested to see if it is functioning by using it on a separate device. If the charger does not work, a new charger can be purchased.
Battery is Defective
If the previous two steps did not solve the problem, it may be a defective battery. The battery can be replaced easily using this guide.
Motherboard is Defective
If none of these solutions fix the issue, the motherboard may be the problem. The motherboard can be replaced easily following this guide.
4条评论
during a charge, my Garmin shows the logo on the screen but it flashes from bright to dim...I had it plugged in for around 20 minutes and tried to turn it on and it will not start...what do I do?
patti421957 - 回复
I fully charged mine and still nothing after looking up the owner's manual it suggested a reset. Hold the on/off button for 12 seconds, it came back on!
Claudia - 回复
I tried that too. Did not turn on or work. Product is awful and I wall save my money for a better GPS that is NOT Garmin
Mikemarr - 回复
I just want to know what is indicated by a yellow/amber light on the car charger. If a device is built with indicator lights, the manual should tell you what the specific indications are. I can’t determine whether I have a problem with the battery, with the vehicle outlet/flow, with the charger itself (replaced the fuse already w/o effect), or something else…
There is a limit to how much I want to spend guessing what’s wrong versus putting the money toward a new (and possibly non-Garmin) product.
Mine is a 2599LMTHD that worked for almost exactly one year and now won’t turn on. It failed to turn on after removing it from my GM vehicle for use in my GM rental car for a road trip (good timing!); I was about 3 hours away from home when I decided to plug it in and use it for a local stop, but it wouldn’t work.
I do really like Garmin. When it works.
L
LoriD - 回复
