学生贡献的维基
一名我们训练的优秀学生制作了这个维基。它不是由iFixit的工作人员进行管理的。
CARD ERROR shows for memory problems
Card needs to be format. Clean the card contacts with a soft, dry cloth. If message still shows repeated to format card. If message still shows, replace card. Contact FUJIFILM dealer for camera malfunction.
Camera Picture looks blurred or the scenery cannot be made out
Select macro mode, cancel macro mode,use focus lock.
Battery is like dead or drained
Warm battery in pocket or other warm place and re-insert immediately before taking a picture, use camera mode to conserve power when shooting, battery has reached end of charging life and there has to be a purchase of a new battery. Charge battery or insert fully-charged spare battery, re-insert battery in the correct orientation.
Camera turns off for no reason
Re-insert memory card, close battery-chamber cover, then turn on camera.
Flash seems to not flash
Choose a different shooting mode, charge battery or insert fully-charged spare battery. Select off for continuous. Turn silent mode off. Choose a different flash mode.
My camera isn't turning on
Try pressing the power button for ten-seconds. Open the camera’s battery door and make sure the battery is properly in the camera. Plug the power cord into the camera and see if the screen responds. Try a different battery.
I keep seeing a small black spot on my pictures
See if the black speck is just on your LCD screen or in your pictures as well. If the black spot is everywhere then you most likely have dust on your CCD image sensor. You will need to open the camera to get to the sensor and clean. If the black speck is only on the LCD screen then your have a bad pixel. You can either ignore it, or replace the screen.
No matter what I do i can’t close my lens
Look for dust or debris holding the lens in place. Try using compressed air to loosen up the dust and debris.If there is no dust and debris then they need replacement.
It looks like ink has spilled in the screen
You are going to have to replace the entire LCD screen.
Buttons will not respond
Try using compressed air and a needle to remove any dust and debris. If this doesn't work you may have to replace the buttons.
The menu looks different than before
Try going through the menu, find the settings and reset the camera. This should take your settings and put it factory standard settings.
0条评论
