学生贡献的维基
来自我们教育项目的一支很棒的学生团队制作了这个维基页面。
Camera Won’t Turn On
I’m trying to turn the camera on but the screen stays off
Switch is Not Moved Over Enough
Make sure you are moving the on/off switch all the way to “ON” and release. If the switch is not pushed fully to the “ON” position, the camera won’t turn on.
Camera Doesn’t Have Batteries
Your camera needs batteries to run. Make sure you have four AA batteries installed at the bottom of the camera.
Batteries are Dead
Your camera will work best with fully charged AA batteries. Make sure the ones inside have power.
Pictures are Blurry
Photos do not appear clear or focused
Lens is Dirty
Make sure the lens is free of debris or smudges. If the lens is dirty, remove any large pieces of debris. Then breathe softly on the lens to create a slight fog before wiping the lens with a soft cloth to remove any dust or smudges.
Not Allowing the Camera to Focus
The camera has the ability to self focus for a picture, but this function is not instantaneous. Wait about 1-2 seconds before pressing the shutter button on a desired shot. This will allow the image to focus.
Camera is Unstable
A moving or unstable camera does not allow for clear photos. Hold the camera steady or place the camera on flat stable surface when taking photos. Using a tripod would also be a consistent way to keep the camera steady.
Screen is Not Responding
The screen is stuck on one picture and the buttons aren’t working
Software Issue
Try performing a hard reset to fix this. Take the batteries out, replace them, and attempt to turn on camera to cycle the power and reset the camera.
Screen is Frozen
Your camera may still be working with the screen frozen. Try a factory reset:
- Press the [Menu/OK] button
- Press the [</ dial left button]
- Press the [V/ dial down button]
- Press the [>/ dial right button]
- Press the[V/ dial down button] 4 times.
- Press the [V/ dial down button] and press [Menu/OK]
Blurry Viewfinder
Whenever I look in the viewfinder, nothing is clear.
Dirty Lens
Try to clean the lens with a microfiber cloth or 100% cotton. Use either rubbing alcohol or deionized water. This will ensure that the lens is not contributing to the dirty viewfinder.
Camera Not Allowed to Focus
Press the shutter button down halfway to allow the camera to focus and have a clearer picture.
Viewfinder Damaged
Look for scratches or smudges that might be affecting the viewfinder clarity. If your viewfinder is broken, check our replacement guide to fix it.
Pictures Not Saving
I'm trying to take pictures, but they don't seem to be saving.
No Memory Card
You need a memory card in your camera for it to be able to save your pictures. Open the bottom door and make sure one is installed.
Memory Card is Full
If you take too many pictures, your memory card will fill up. Delete existing pictures or use a computer to export pictures off of your card.
2条评论
If the screen stays off, disconnect the cord if it’s plugged into the camera.
Lori Miller - 回复
What a blank detected option? How to solve?
Atta Rehman - 回复
