学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Laptop Fails to Turn On
The computer will not turn on or show signs of having turned on.
Faulty Power Cord
If the cord fails to charge the battery or provide power to the computer, make sure that the cord is plugged into the computer, the wall, and the converter. If the problem persists, the cord may be broken, and you may want to consider buying a new one.
Faulty Battery
If the battery will neither charge nor provide power to the computer, you may need to buy a replacement battery. To replace the battery, turn the laptop upside down and pull the switches keeping the battery in place. This will pop out the battery. Remove the old battery and place the new battery in the computer and make sure you hear a click. This signals that the battery is locked in place. A video for this process can be found here.
Laptop Won't Boot
The computer displays an error message instead of loading the operating system.
Insufficient or bad RAM
If the computer shuts down randomly or during memory intensive tasks, your computer may have either bad or insufficient RAM. Install more RAM to your computer; the guide is not for this model, but it is similar enough until a proper guide is made.
Bad Processor
If the computer will not boot at all, or shows an error message, the processor may be bad. You will need to buy a new one to replace it.
Corrupt Operating System
If the boot sequence fails when the computer tries to load the operating system, the operating system may be corrupt. To see if this is the problem, attempt to boot the computer from an operating system disk if you own one. If the computer boots from the disc, you will need to reinstall the operating system. If it still fails to boot, the hard drive may have gone bad.
No Display
The monitor does not display anything, but you know the computer is turned on.
Second Display Set as Default
Your computer may be sending the video to the external monitor port. To fix this, plug a monitor or TV into the ports in the back of the computer.
Wireless Connection Does Not Work
The computer will not connect or cannot detect an available internet connection.
Wifi Disabled
Check to make sure the wifi switch on the side of the laptop is set to "on".
Wifi Card Missing
If you are sure that wifi is enabled, it is possible that the internal wifi card is damaged, not properly connected, or missing. An external wifi adapter can be purchased here (replacement guide pending).
Sound Does Not Work
The sound from the computer is distorted or there is no sound at all.
Internal Speakers Not Working
Right click on the speaker button on the bottom right hand side of the monitor and ensure that the speakers are not muted. Adjust the volume, treble, and bass options if the problem persists. If this does not solve the problem, reinstall the audio driver using this guide.
0条评论
