学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Laptop failing to connect to Wi-Fi
The laptop will not connect/stay connected to Wi-Fi.
Drivers are out of date
If your computer is having trouble connecting or staying connected to Wi-Fi, it is important to ensure whether or not the drivers were installed in the correct order. Drivers should be downloaded and installed directed from the Dell website, rather than being found from a third party. Here is a link on how to install the drivers in the correct order as well as the exact order of installation. Your computer’s Dell Warranty Status will state the wireless adapter driver to install by inputting your operating system and selecting a network.
Wifi module malfunctioning
If none of these fix what is going on than your Wi-fi module may need to be replaced, here is a link to the guide on replacing the Wi-fi module.
Laptop not charging
The laptop won’t charge or hold a charge.
Debris in the charging port on the computer or the cable
The first thing to check on your computer is the charging port and cable themselves. Sometimes debris can get stuck in the ports and prevent a proper connection to charge your computer. The easiest way to fix this issue is to use a can of compressed air and blow out any debris in the charging port and the end of your charging cable that plugs into your computer.
Bad charging cable
Another likely possibility is an issue with the charging cable. A way to rule this out is by plugging your cable into another computer that uses the same spec charger. This will tell you whether its a charger issue or a computer issue. If it is a charger issue than the best course of action is to purchase a new charger for your computer with the same specs.
Faulty DC jack
If all else fails then what could be causing the issue is a bad DC jack. This could simply be due to water damage or possibly a cable disconnected internally that powers the DC jack, here is a link to get to the DC jack and replace it with a new one.
Games play poorly
Games won’t load or play poorly on my computer.
low spec graphics processing unit (GPU)/centeral processing unit (CPU)
A common assumption with the Dell Inspiron 15R 5537 is that it comes with AMD Radeon HD 8670M integrated graphics but this feature is an add on when originally purchased. So if you can not find the AMD graphics software in the control panel then it is likely that your computer only has Intel integrated graphics. But a solution to this is to upgrade to the AMD graphics by changing your motherboard to the one with AMD graphics, here is a link to get to the motherboard.
The power button won’t turn on the computer
Power button does not respond/turn on the computer when being pressed
The computer is not charged
If the power button LED doesn’t light up and the computer doesn’t turn on when pressing and holding the power button, make sure the computer is charged. This can be done by plugging the proper charger into your computer.
Power button circuit board replacement
If the computer is charged and the power button still doesn’t respond when being pressed, the power button circuit board may need to be replaced.
Laptop showing a black screen
The display has no video.
The display screen is broken
A possible issue is that your screen may be damaged or broken. First check the screen for any cracks, dents, or liquid damage. If there is any of these found, the best course of action is to replace the screen. To replace the display screen, follow steps 1 to 27 of the motherboard replacement guide here.
Hard drive failure
Immediately after starting up your computer press and hold the f12 key to boot into the Boot menu to run a diagnostics check. The diagnostics should be checked on all of the hardware and once that is complete run a test for the hard drive. The test will show you what has failed and may need to be replaced.
2条评论
My computer on Startup after turning on after being dead will display pink lines going acrossed the screen and the laptop will not function until they are gone in about 5min
Sebastian Langford - 回复
Hi Sebastian,
This is cody, one of the original creators of this guide. From what you describe it could be generalized to a bunch of different things but in many cases if the lines are horizontal it will be GPU related and if they are vertical it will be LCD screen related. Although you didn't specify which way the lines are going I can give a general solution for both. For vertical lines, the best solution is to replace the screen, which we have a guide here on how to do, but those can be expensive to do so I would suggest using an external monitor such as a TV or maybe one you find used from somewhere locally near you and just us it as a normal desktop PC. Just make sure your external monitor and computer both have HDMI ports to connect them to.
If the lines are horizontal then the cause might be due to the GPU drivers being corrupted or outdated. This will require you to uninstall the current drivers and find the new updated ones from the GPU manufacturer's website. Just be careful of fake websites.
Cody Charnisky -
