学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Cobra Will Not Power On
Cobra is unresponsive when trying to turn it on.
Damaged Charger Wire or Damaged Drop-In Battery Charger
The charger may not be providing any electricity to the battery. In this scenario, the charger will have to be replaced. Buy a replacement charger.
Depleted or Exhausted Battery
The battery itself is not able to hold a charge or provide power to the device. To get the radio working again, the battery must be removed from the back of the radio and replaced with a new one. Buy a replacement battery and install it by inserting it into the radio.
Cobra Screen Will Not Display An Image
Cobra screen is not responding to any inputs.
Motherboard No Longer Functions
The motherboard may have died due to a variety of different factors, such as drops, issues with the capacitors or simply just old age. Making the radio work again requires complete disassembly of the radio and replacing the old motherboard with a new one. Buy a replacement motherboard and install it.
Cobra Is Unresponsive When Buttons Are Pressed
Pressing a button does not translate into an action on the device.
Buttons Are Worn Down/Jammed
The buttons themselves may be worn down, and no longer make contact with the motherboard. To get the buttons to work again, the old rubber buttons must be replaced with new ones, which requires disassembly of the radio. Buy replacement buttons and install them.
Cobra Cannot Communicate With Other Radios
Cobra produces static or no sound when trying to communicate with other radios.
Damaged/Worn Down Antenna
The antenna may be damaged or worn down from prolonged usage. The broken antenna could prevent the radio from pickup up any signals. All that must be done to fix this is to unscrew the old antenna from the top of the radio and replace it with a new one. Buy a replacement antenna and install it.
0条评论
