学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Camera Does Not Turn On
Camera does not appear to be on and nothing is on the LCD screen.
Low Battery Level
Make sure the batteries you installed are correctly installed and are lithium 6V batteries.
LCD Broken
If the camera is working and the LCD screen is not on, the LCD screen may need to be replaced. (Replacement guide will go here)
Internal Component Malfunction
If the camera does not turn on at all after checking the batteries, an internal component may be disconnected or dysfunctional. The malfunctioning component should be replaced.
Camera Will Not Take Pictures
No Memory Card
Verify that the memory card is in the slot and it is installed correctly.
Memory Card Inserted Incorrectly
Verify that the card is inserted properly and there are no jams.
Shutter Curtain Or Mirror Obstructed
Verify that the shutter curtain and mirror are not stuck and there are no obstructions. The shutter curtain is the small black doors located outside the film lens.
An internal component may be disconnected or dysfunctional. The malfunctioning components should be replaced.
Poor Picture Quality
- Dirty Lens***
Clean lens with a blower brush to remove dust. Then use lens cleaning paper and fluid to gently wipe the lens in a spiral from the center to the outer edge.
Camera Shaken During Picture Taking
Keep the camera steady or use a tripod.
Flash Does Not Work
Flash Turned Off
The camera's flash setting may be off. Turn the flash setting on and verify that the flash is working. Settings are located on the back panel of the camera near the arrow buttons.
Flash Not Charged
Give the flash unit time to charge before taking pictures.
- Flash Unit Broken***
The flash unit of the camera may be damaged. The flash unit should be replaced.
4条评论
When I hit the arrow in the box icon to see the picture I just took, the camera shuts off & I am
not able to see my taken pictures? This just started as everything was A ok.
I just recharged the battery first because I saw it was blinking & low - no problem, I have done
this many times. Now, I see no pictures that I take. Please help asap! Thanks Paula
paula meyns - 回复
When I hit the arrow in the box icon to view picture I have just taken, the camera shuts off.
This just started as everything was !A ok. I did just charge battery as I noticed it was lot but
I have done with many times. What is happening? Please help ASAP. Thanks. Paula
paula meyns - 回复
I have canon POWERSHOT ELPH 150IS. Liquid had gotten on or in the camera and now there are spots when you look at pictures through the view finder. The lens is dirty on inside. How can I get this cleaned?
Vic Riccio - 回复
My camera can turn on, but the display is blank. After pushing the menu button for several seconds, the image appears. for menus, photos, video, and to retrieve the data from the SD card. What is wrong with the internal mechanism?
Manuel gonzalez-gil - 回复
