学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
No Sound Coming From Bose Wave Radio
You have turned the volume to its max and you still can’t hear anything.
External Cord is Plugged into the Variable Out
Unplug any cords that are plugged into the variable out. There cannot be any cords plugged into the variable out component in order for sound to play.
Bose Wave Radio is Not Plugged In
Double check that the power cord is connected to both the Bose Wave Radio and a wall outlet. If not plugged in at both ends, plug in the cord to the back of the speaker and the outlet.
Bose Wave Radio is Set to the Wrong Input
Make sure that the Bose Wave Radio is set to the input that you want to use. To use the AUX input, press the AUX button. To use the radio, press the AM/FM button, and press the button again to switch between AM and FM.
Speakers are Broken
If no other troubleshooting corrected the audio problem, the speakers are most likely broken. You can order replacement speakers separately.
Screen is Too Dim
You cannot read the display because it is too dim.
The Display is Not Brightened All the Way
You can brighten the display by holding down the CLOCK SET button and pressing the ‘volume up’ button. Otherwise, the display depends on how much light is in the room, so it automatically adjusts depending on the brightness in the surrounding area.
FM Radio Sounds Distorted
You hear static or poor sound quality when listening to the FM radio.
Radio is Not Tuned Correctly
Press the tuning buttons until the radio is set to a station with clear sound.
Antenna is Poorly Positioned
The antenna is built into the power cord, so it will work best if the cord is stretched out as far as possible between the outlet and wall.
Alarm Will Not Turn Off
You cannot make the alarm stop making noise.
Alarm Has Not Been Turned Off
Press the ON/OFF button.
Cannot Disable Daily Alarm
You cannot turn off the daily alarm.
Alarm 1 is Enabled
Press ALARM MODE or ALARM until the display shows no Alarm 1 mode indicators.
Alarm 2 is Enabled
On the control panel, hold down ALARM SET and press ALARM MODE until the ALARM 2 indicator flashes. Release ALARM SET. On the remote, press TIME, then press ALARM . The ALARM 2 indicator flashes. Press TIME again. With ALARM 2 flashing, press ALARM MODE or ALARM until the display shows no Alarm 2 mode indicators.
Can’t Change Time On Clock
You cannot set the clock to the correct time.
The Clock is Set to the Wrong Time
Hold down the CLOCK SET button and press TUNING up or down. Release the TUNING button to stop.
61条评论
bose AWRC1 remote old and new does not work with new bateries
cd will work when i unplug unit
clock works
thx E
EDWIN SAKS - 回复
both remotes do not turn unit on
EDWIN SAKS - 回复
I can play one cd with sound. The radio has no sound. Also, I can't get the attached 5 disc cd to play.
Signed , frustrated in NC
Jeanie1960 - 回复
My Bose radio plays fine for @ 15 min then popping and static noises and after @20 min of static no sound. I turn it off and on again with remote and it plays fine and the cycle starts again. ever hear of this ?
Robert Janky - 回复
My system will not come on with the remote. I have replaced the remote battery. There is no manual power button!
MDS
Maelyn D Smith - 回复
