学生贡献的维基
来自我们教育项目的一支很棒的学生团队制作了这个维基页面。
Low Disk Space
The device no longer has the capability to add files or programs
Build up of Unwanted System Files
Try running the disk cleanup program
This will get rid of any unneeded program files and should improve the performance of the device. Running the option located next to the cleanup tab will aid in performance.
1. Open file finder
2. Click on This PC
3. Select local disk (single click)
4. At the top of the program, window locates the tab labeled manage and select it.
5. Then hit the option labeled cleanup
Hard Drive is Full
Uninstall any unwanted programs or Look at replacing the hard drive. [Hard Drive Replacement Guide]
Games Lag
There is a delay between when a key is pressed on the device and when the action occurs on screen
Games Graphics are too Intensive
Try lowering the graphics quality in the game. This option can usually be found in the games setting menu, under the game interface.
The graphics card might be old or outdated and need replacing [Graphic Card Replacement Guide]
Issues with Internet Connectivity
If it is an online game check the internet connectivity and the bandwidth of the router the computer is connected to.
Game Requires Higher Computing Capacity
Consider upgrading RAM cards. [Ram Card Replacement Guide]
The Device is Overheating
Device is hot to the touch and has a slow reaction time
Blockage in the Device Exhaust Vents
The device features vents that over time collect build up. Use canned air to clean out the vents. Remember to keep the can vertical to reduce the amount of moisture.
Faulty Fan
The device fan may stop working after the laptop boots up. Shut down the device and restart after a few minutes. If this is not the source then check the capacitor. [ Cooling Fan Replacement Guide]
Incorrect Device Placement
Improper placement of a laptop can block the airflow from the vents. Placing the device on a hard flat surface will allow proper ventilation.
The Device is Overloaded when Running Standard Operations
Unnecessary background programs can cause the device to lag
Device Running Slow
When the device is freezing or moving slower when being used. Try closing programs.
1. Go to Control Panel
2. Go to "Programs and Features”
3. Close applications/programs that are running in the background.
Basic Device Maintenance
Check for operation updates as well as applications and other programs that you use daily up to date regularly or as needed.
The Webcams Malfunctioning
Device can no longer access the camera, or the image quality is poor
Webcam/webcam Software is Damaged and Needs Replaced
If the webcam itself is damaged it will need to be replaced as a whole. If the issue is related to the webcam diver damage you can run a hardware troubleshooter to see if the issue can be fixed remotely
a. Press Windows key + C on your keyboard to show the Charms bar.
b. Type Troubleshooting and click Troubleshooting under Settings.
c. Now type Hardware Troubleshooter in the search option.
d. Click on Hardware troubleshooter to run the troubleshooter.
Outdated Webcam Software
Check for manufacturer software updates to ensure you are running on the latest software for your webcam. Running on an old software can cause malfunctioning in the webcam.
0条评论
