学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Important Note
In all cases for troubleshooting, the first thing that should be checked is if any Windows updates are available. Yes, even the optional ones! Most of the time the issue can be solved with updates so make it the first step! This can be performed by going into Settings, then Updates, then checking for updates.
Low Performance in Applications and Games
Some users have experienced an unexpected decline in performance in comparison to other products.
BIOS Could be Out of Date
Since the release of the device, there have been quite a few BIOS-level fixes. The most recent one can be downloaded at this link here.
To update the BIOS, open the downloaded zip archive, as well as the application in it. The application will give on-screen instructions on how the BIOS will be updated. Additionally, make sure the laptop is plugged into power throughout this process.
Graphics Driver May Need Updating or Reinstallation
Make sure that the graphics driver is updated by opening GeForce Experience and checking for updates. If GeForce Experience does not exist on the computer, the application can be downloaded here.
If there aren't any updates or the performance was not improved, the driver can also be uninstalled and reinstalled. Open Settings and go into the Apps section. Find the NVIDIA Driver package and uninstalled it. The display may flash a few times and is normal. Once uninstalled, install GeForce Experience to find the most recent driver for the system.
Default Power Settings Can Lower Performance
In some cases, the power draw of the computer is limited and is hindering the performance. Open Settings and search for "Power & Sleep." On the bottom or the right side of the menu, there is a button for "additional power settings." This will open another window to be able to choose a power plan. Make sure this power plan is on "performance" instead of "battery saver."
"Fading” Pixels on Display
The display will appear to be "faded" in a separate area. A photo example of this can be found here.
The Display Could be Damaged
Check the left, right, and top sides of the device for an HDMI output. This model has an HDMI port on the right side of the device. Use an HDMI cable to plug the laptop into a TV or monitor with an HDMI input. HDMI is the only display output that exists on the device. If the projection on the secondary display does not have the "fading" effect, this is a hardware issue with the display, and it needs to be repaired.
To double-check, a second HDMI cable can be tested on the connection. The first one could be faulty, and using a second one gives insurance on the issue.
Windows May be Corrupted
Windows has an option to "refresh" where it will remove all applications from the system, but keep personal files. It also reinstalled a fresh version of Windows. Go into Settings, and in the search bar type "refresh." The first option will be a "reset this pc" prompt, and pick the option to keep all of your files. The on-screen instructions will guide you through the rest of the process.
Faulty Graphics Card
If all else fails, you may be experiencing "artifacting." Artifacting is a visual error when the encoding of data fails. The graphics card is what encodes this data, and transmits it to the display. Check the warranty on your device here, and consider sending it out for service.
Audio Distortion or Absence of all System Sounds
Some users have experienced the "clicking" or complete absence of sounds coming from the device.
Audio Driver May Need Updating or Reinstallation
Open Device Manager by right-clicking the Windows start menu and click the "Device Manager" option. Uninstall the "Realtek Audio Driver" from the Audio dropdown menu. Once uninstalled, restart the computer. The driver will be replaced with a default driver that Windows has saved.
Alternatively, repeat the same steps by uninstalling the driver, but do NOT restart. On the Acer support page for this device which can be found here, download the most recent "Realtek Audio Driver." Open and install the package by following the on-screen instructions, and restart the computer.
Internet Dropping Out Intermittently
The network will randomly drop out from the device and disconnect, to then reconnect seconds later.
The Local Network is Dropping Out
If possible, try running the device on a completely different network. Doing this will diagnose whether the local network or the device is the issue.
Network Driver May Need Updating or Reinstallation
Open Device Manager by right-clicking the Windows start menu and click the "Device Manager" option. Uninstall the "Intel Wireless Driver" from the Network Adapters dropdown menu. Once uninstalled, restart the computer. The driver will be replaced with a default driver that Windows has saved.
Alternatively, repeat the same steps by uninstalling the driver, but do NOT restart. On the Acer support page for this device which can be found here, download the most recent "Wireless LAN Intel Driver." Open and install the package by following the on-screen instructions, and restart the computer.
Touchpad is Unresponsive
The touchpad is not functioning correctly and the cursor cannot be moved.
Touchpad Could be Disabled
This device has a way to enable and disable the touchpad with a press of a button. Press Fn and F7 together to toggle on/off the touchpad. Test to see if it works!
Touchpad Settings Need to be Reset
Open Settings and search for the "Touchpad" menu. At the bottom of the menu, there is a button to reset all touchpad settings. Click that button and restart the computer.
Touchpad Driver May Need Updating or Reinstallation
Open Device Manager by right-clicking the Windows start menu and click the "Device Manager" option. Uninstall the "Synaptics/ELANTECH Touchpad Driver" from the Interface dropdown menu. Once uninstalled, restart the computer. The driver will be replaced with a default driver that Windows has saved.
Alternatively, repeat the same steps by uninstalling the driver, but do NOT restart. On the Acer support page for this device which can be found here, download the most recent "Touchpad Driver." There are two versions depending on the manufacturer of the touchpad. When uninstalling, if the driver said "Synaptics" or "ELANTECH," the same driver needs to be reinstalled. The drivers are not cross-compatible. Open and install the package by following the on-screen instructions, and restart the computer.
3条评论
I have this model of the nitro 5 and the entire computer is bricked, no signs of life, the charging light won’t turn on when plugged in, the fans don’t turn on when I press the button, I know it isn’t the power supply and nothing seems to be working, no obvious blown capacitors or anything like that, nothing seems to work. Please can someone try helping me?
Fionn bellette - 回复
Unfortunately not a help, just a shout out for the same problem here....have you managed to fix it ! How?? 🙏
jgdias -
If you still care, My issue ended up being that there was a loose capacitor , the laptop is still no fixed but I know the issue now, try looking inside your laptop and look for obviously broken parts or things being disconnected or where they are not meant to be.
Fionn bellette -
