跳转到主内容
Dell Latitude D600 Display Replacement
你所需要的
  1. Dell Latitude D600 Display Replacement, Display: 步骤 1 中的图像 1,1
    • Remove the 6 screws underneath the rubber things - located in red
  2. Dell Latitude D600 Display Replacement: 步骤 2 中的图像 1,2 Dell Latitude D600 Display Replacement: 步骤 2 中的图像 2,2
    • Use your spudger to pry off the front case
    • Go all around the perimeter and pop it off
  3. Dell Latitude D600 Display Replacement: 步骤 3 中的图像 1,1
    • Remove the 6 screws holding in the display screen
  4. Dell Latitude D600 Display Replacement: 步骤 4 中的图像 1,3 Dell Latitude D600 Display Replacement: 步骤 4 中的图像 2,3 Dell Latitude D600 Display Replacement: 步骤 4 中的图像 3,3
    • Remove the screw holding in the display cable connector
    • Pull the black tab up to remove the display cable connector
  5. Dell Latitude D600 Display Replacement: 步骤 5 中的图像 1,1
    • Slowly Remove the wire from the joints holding it in
  6. Dell Latitude D600 Display Replacement: 步骤 6 中的图像 1,2 Dell Latitude D600 Display Replacement: 步骤 6 中的图像 2,2
    • The computer is happy you are fixing him
    • Thats it, display is now removed feel free to replace it by doing the steps in reverse
结论
3等其他人完成本指南。
Joseph
于07/16/14注册
1,497 声望
创作了5篇指南
一条评论
I see you removed the keyboard by seeing it in the background of the last image however, I do not see the steps instructing everyone on how to remove the keyboard.
Darren - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 19
总计 2,095
