跳转到主内容
iomega LDHD250-U Teardown
你所需要的
  1. iomega LDHD250-U Teardown, Remove Rear Screws: 步骤 1 中的图像 1,1
    • Remember to power off and unplug the unit before opening it up!
    • Remove the two PH #0 Screws
  2. iomega LDHD250-U Teardown, Removing the cover: 步骤 2 中的图像 1,2 iomega LDHD250-U Teardown, Removing the cover: 步骤 2 中的图像 2,2
    • After removing the back part of the unit, slide the front part out.
    • Remember to put aside the center part you removed
  3. iomega LDHD250-U Teardown, Removing the Hard Drive: 步骤 3 中的图像 1,3 iomega LDHD250-U Teardown, Removing the Hard Drive: 步骤 3 中的图像 2,3 iomega LDHD250-U Teardown, Removing the Hard Drive: 步骤 3 中的图像 3,3
    • There are two ways to remove the Hard Drive
    • 1. Removing the 4 screws on the side of the unit
    • 2. Sliding the HDD back and then releasing it (my unit will not slide back)
    • The HDD can now be lifted out, unplugged, and replaced, upgraded, or keep it the same.
    • Pull up and unplug as the cables can break if too much force is applied
结论
Nate Pritzker
于10/12/17注册
431 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 23
总计 913
