在此拆机指南中的精选工具
简介
We took apart the iPod shuffle Special Edition on September 11, 2009. This iPod features an incredibly shiny stainless steel enclosure. According to Apple's marketing-speak, "It's as brilliant as your taste in music."
这个拆解是不是维修指南。 要维修你的的iPod shuffle 3rd Generation,请使用我们的服务手册
  1. If you like shiny things, Apple has an iPod for you. It's like getting a free mirror! And it's only $20 extra.
    • If you like shiny things, Apple has an iPod for you. It's like getting a free mirror! And it's only $20 extra.
    • Sadly, the shuffle doesn't come with matching shiny headphones.
    • Contrary to Apple's typical claims of "smaller packaging to save the environment," this iPod's packaging is 65% larger than the original 3rd Gen shuffle.
    添加评论
  2. We've already taken apart one of these little guys, but we wanted to see what makes the special edition so special.
    • We've already taken apart one of these little guys, but we wanted to see what makes the special edition so special.
    • At least until we use it, the mirror-finish reflects beautifully. With the help of the new shuffle, our camera can do a self-portrait.
    添加评论
    • This picture makes things look easy. The picture is a lie. This picture comes after about an hour of frustration trying to open this iPod.
    • We finally used a putty knife and an excessive amount of force to pry the iPod open.
    • The new shuffle weighs in at 17.2 grams, nearly 61% more than the 10.7 gram aluminum shuffle.
    • That means you can buy special edition shuffles for only $2,613 per pound, while the regular shuffle will set you back $3,352 per pound.
    添加评论
  3. 传播 Fixmas 欢乐
    Get $12 off your purchase of $50 or more with code FIXMAS12
    传播 Fixmas 欢乐
    • Here are the normal (left) and special edition shuffles. Not a surprise, but not much new to see here.
    • This shouldn't come as a surprise, but the new shuffle is a lot heavier. It is steel after all.
    添加评论
    • The most daunting task of this procedure....removing the one single screw.
    • The black 3rd generation had a black screw, while our silver special edition had a silver screw. It looks like Apple gives you matching screws.
    添加评论
    • Prying the logic board and battery out with the flat end of a spudger.
    • Things don't appear different here. The battery is still a tiny 0.27 watt-hours.
    添加评论
    • The internal parts and the stainless steel case seperated.
    • After removing the internals, the stainless steel casing weighs 12 grams. That doesn't seem like much, except that the iPod itself only weighs 5 grams. Over 70% of this iPod's weight comes from its shell!
    添加评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 33
总计 37,678
