跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的iPod Nano 2nd Generation,请使用我们的维修手册
  1. iPod Nano 2nd Generation Teardown, iPod Nano 2nd Generation Teardown: 步骤 1 中的图像 1,2 iPod Nano 2nd Generation Teardown, iPod Nano 2nd Generation Teardown: 步骤 1 中的图像 2,2
    • Before we take it apart, here's some images of the new packaging.
    • Here's the sexy, new, 52% less volume packaging Steve was so excited about.
  2. iPod Nano 2nd Generation Teardown: 步骤 2 中的图像 1,1
    • The new packaging is innovative. Plastic retainers hold the iPod on top and bottom, and you must flex the plastic packaging to get the iPod out.
  3. iPod Nano 2nd Generation Teardown: 步骤 3 中的图像 1,1
    • Meet the family. From left to right: Mini, new blue Nano, new black Nano, old black Nano.
    • Ah, what to call it? iPod Nano Gen 2? iPod Mini Gen 3? Remastered iPod Nano? We vote for 'that little blue music thingy.'
  4. iPod Nano 2nd Generation Teardown: 步骤 4 中的图像 1,1
    • Goodies! Left to right:
    • iPod
    • Fold-out quick start guide (includes two small white Apple stickers)
    • Plastic 'dock'
    • New earbuds
    • USB docking cable
    • The center button is concave, as opposed to the old Nano (flat), and old Mini (convex).
  5. iPod Nano 2nd Generation Teardown: 步骤 5 中的图像 1,1
    • It may be thinner than the old Nano, but it's sure not by much.
  6. iPod Nano 2nd Generation Teardown: 步骤 6 中的图像 1,1
    • The back shouldn't scratch instantly anymore.
  7. iPod Nano 2nd Generation Teardown: 步骤 7 中的图像 1,1
    • On to the disassembly!
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    • Opening the iPod can be challenging. Don't get discouraged if it takes you a few tries before the iPod is opened.
  8. iPod Nano 2nd Generation Teardown: 步骤 8 中的图像 1,1
    • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic top. Be careful not to damage the soft plastic with your tool.
    • The new Nano more closely resembles the old Mini design than the previous iPod Nano generation.
  9. iPod Nano 2nd Generation Teardown: 步骤 9 中的图像 1,1
    • Lift the top bezel off of the iPod.
  10. iPod Nano 2nd Generation Teardown: 步骤 10 中的图像 1,1
    • Pry the bottom bezel off using the same technique as the top.
  11. iPod Nano 2nd Generation Teardown: 步骤 11 中的图像 1,1
    • Lift the bottom bezel off. It's glued on using a mild adhesive, so some force may be required.
  12. iPod Nano 2nd Generation Teardown: 步骤 12 中的图像 1,1
    • Remove the two Phillips #00 screws from either side of the dock connector.
  13. iPod Nano 2nd Generation Teardown: 步骤 13 中的图像 1,1
    • Remove the two Phillips #00 screws from the top of the iPod.
  14. iPod Nano 2nd Generation Teardown: 步骤 14 中的图像 1,1
    • Pry out the headphone jack slowly with a spudger. Do not remove the headphone jack entirely, as it is connected via a fragile ribbon connector to the click wheel.
  15. iPod Nano 2nd Generation Teardown: 步骤 15 中的图像 1,1
    • Once you have pulled the headphone jack out of its slot, remove the Phillips #00 screw formerly concealed beneath it.
  16. iPod Nano 2nd Generation Teardown: 步骤 16 中的图像 1,1
    • Remove the metal bracket surrounding the docking connector.
  17. iPod Nano 2nd Generation Teardown: 步骤 17 中的图像 1,1
    • Disconnect the headphone and click wheel cable from the logic board. It's tricky to see what you're doing, so you'll have to feel the connector inside the iPod with the spudger.
    • You need to pry the connector toward the front of the iPod until it comes loose from the logic board.
    • Do not entirely remove the headphone jack. The cable is still connected to the click wheel.
  18. iPod Nano 2nd Generation Teardown: 步骤 18 中的图像 1,1
    • Use a spudger to push the logic board assembly out of the casing. The click wheel and headphone jack should remain in the iPod.
    • Be careful not to catch the headphone jack and click wheel on the logic board as you remove the logic board and display.
  19. iPod Nano 2nd Generation Teardown: 步骤 19 中的图像 1,1
    • Completely remove the display and logic board from the iPod.
  20. iPod Nano 2nd Generation Teardown: 步骤 20 中的图像 1,1
    • We got it apart!
    • The casing is certainly more scratch-resistant than the previous Nano. We were careful and didn't scratch the case at all.
  21. iPod Nano 2nd Generation Teardown: 步骤 21 中的图像 1,1
    • Pry the metal bracket off the back of the display. Make sure you only pry off the bracket and not the clear shielding on the rear of the display.
  22. iPod Nano 2nd Generation Teardown: 步骤 22 中的图像 1,1
    • Lift up the display and use a spudger to flip up the black plastic retaining bar holding the display ribbon cable in place.
  23. iPod Nano 2nd Generation Teardown: 步骤 23 中的图像 1,1
    • Slide the display ribbon out of its connector and lift the display off of the logic board.
  24. iPod Nano 2nd Generation Teardown: 步骤 24 中的图像 1,1
    • Left: new Nano logic board and battery.
    • Right: old Nano logic board and battery.
    • The new battery is thinner, but significantly larger.
    • The new Nano uses Samsung flash memory, just like the previous model.
    • Whatever you do, don't throw your new iPod into a fire!
  25. iPod Nano 2nd Generation Teardown: 步骤 25 中的图像 1,2 iPod Nano 2nd Generation Teardown: 步骤 25 中的图像 2,2
    • Close up of logic board. Here's some extra-large top and bottom logic board photos.
    • Notice the Apple logo on the ARM chip. The numbers on it read: 33753291 8701 N02R5Q5 0627 ARM.
    • That's it, folks! We sell parts for iPods (including this one), so check out our iPod parts store to fix up your old and broken iPods.
3条评论
sera que lo puedo pintar su skin es plomo pero quiero que sea azul.
Myriam Sarango - 回复
I can’t do this as my iPod has dents where the screws are
Mix Vidios - 回复
What could help is pushing out the metal with a screwdriver.
Ad123re -
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 37
过去 30 天: 243
总计 139,757
