跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的iPod Nano 1st Generation,请使用我们的维修手册
  1. iPod Nano 1st Generation Teardown, Open The iPod: 步骤 1 中的图像 1,2 iPod Nano 1st Generation Teardown, Open The iPod: 步骤 1 中的图像 2,2
    • 1. Using an ipod unclipping tool (which could be a knife or similar to it), unclip the outer casing by putting the tool up to the connection point. This should pop the case off. Note that force will need to be used.
  2. iPod Nano 1st Generation Teardown: 步骤 2 中的图像 1,1
    • 2. Remove the circuit board by unscrewing the 3 screws (there is 1 more screw but dont unscrew it, it holds the headphone jack) that hold it down. Note that specialised screwdrivers may need to be used.
  3. iPod Nano 1st Generation Teardown: 步骤 3 中的图像 1,2 iPod Nano 1st Generation Teardown: 步骤 3 中的图像 2,2
    • 3. Carefully remove the connected wires underneath the motherboard to disconnect the clickwheel and the screen.
  4. iPod Nano 1st Generation Teardown: 步骤 4 中的图像 1,3 iPod Nano 1st Generation Teardown: 步骤 4 中的图像 2,3 iPod Nano 1st Generation Teardown: 步骤 4 中的图像 3,3
    • 4. The screen has 3 different sections, each held down by glue so necessary force is needed. First remove the acrylic backing that supports the screen and then the main part of the screen. The last thing to remove is the paper-thin cover.
  5. iPod Nano 1st Generation Teardown: 步骤 5 中的图像 1,3 iPod Nano 1st Generation Teardown: 步骤 5 中的图像 2,3 iPod Nano 1st Generation Teardown: 步骤 5 中的图像 3,3
    • 5. Removing the touchpad is easy and simple as there are layered parts on top of each other, just simply and carefully pull them off.
  6. iPod Nano 1st Generation Teardown: 步骤 6 中的图像 1,1
    • 6. Finally you should have the ipod dismantelled and you should be able to put the ipod back together.
Craig Lawrence
于03/11/10注册
444 声望
撰写一个指南
6条评论
when i put the rear cover back on, the charging station doesn't line up correctly and the charging station sticks out a bit. any advice?
krnchang - 回复
is the batter swollen
Derek King - 回复
Yes, happened to a Zune 80 I have
CTCL -
Thank you for this - took the fear factor out of changing battery on my much loved Nano!
jimbradshaw - 回复
It’s extremely hard to connect LCD and Button cables. I screwed it up while reconnecting the cables. IF, you want to disassemble this machine by fun, don’t ever try it.
Sizun Cho - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 41
过去 30 天: 135
总计 28,618
