跳转到主内容
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
这个拆解是不是维修指南。 要维修你的的iPhone 6,请使用我们的维修手册
  1. iPhone 6 Teardown, iPhone 6 Teardown: 步骤 1 中的图像 1,3 iPhone 6 Teardown, iPhone 6 Teardown: 步骤 1 中的图像 2,3 iPhone 6 Teardown, iPhone 6 Teardown: 步骤 1 中的图像 3,3
    • Unboxing the iPhone 6: yup, it's a phone.
  2. iPhone 6 Teardown: 步骤 2 中的图像 1,1
    • After removing the familiar two Pentalobe screws we use a suction cup to carefully lift up the screen to give us enough space to run a plastic tool down the edges to release the screen clips
    • Unlike the 5s, The 6 Touch ID cable is now routed up the back of the screen, so we don't have to worry about accidentally ripping the touch ID cable.
  3. iPhone 6 Teardown: 步骤 3 中的图像 1,2 iPhone 6 Teardown: 步骤 3 中的图像 2,2
    • The screen connectors are covered by a metal plate, similar to the previous models.
    • This plate is held by 5 screws this time.
    • There are 5 connectors under this plate: LCD/Touch Sensor/Front Camera, Rear Camera and TouchID.
  4. iPhone 6 Teardown: 步骤 4 中的图像 1,2 iPhone 6 Teardown: 步骤 4 中的图像 2,2
    • The battery is very well stuck in. With a bit of heat and a little deformation of the battery, we were able to get it out. (There's probably a pull tab to remove the battery, but we didn't find it.)
    • The battery is rated at 3.82V, 6.91Whr.
  5. iPhone 6 Teardown: 步骤 5 中的图像 1,1
    • Removing the logic board requires the removal of many screws.
    • Fortunately for DIYers, Apple have placed the chips away from most of the screws so there is less risk of tool slip damage.
  6. iPhone 6 Teardown: 步骤 6 中的图像 1,1
    • The iPhone 6 rear camera: not as big as its optically stabilized brother.
  7. iPhone 6 Teardown: 步骤 7 中的图像 1,1
    • The iPhone 6 logic board.
  8. iPhone 6 Teardown: 步骤 8 中的图像 1,1
    • The vibration motor is now inside a metal case!
    Is this a linear oscillation vibrator like the 4S? Or the more standard type found in the 5/5s?
    ASheikh - 回复
    hi guys i would like to share my experience with all of you , I was android user and using Samsung galaxy S5 , when Iphone 6 has launched in september 2014 i was decided to buy Iphone 6 in Pakistan and sell my S5 android .
    In november i have bought iphone 6 16 GB from Pakistan online store http://www.vmart.pk/apple-iphone-6-16gb-... . My friends are very happy to see my iphone 6 and they are all apple products lover. Everything is going fine with my iphone but when put on my iphone in my stretchable jeans my iphone is bend in curve. i am very upset because of my set is to expansive please help me guys.
    Thanks
    kashif - 回复
  9. iPhone 6 Teardown: 步骤 9 中的图像 1,1
    • The loudspeaker.
  10. iPhone 6 Teardown: 步骤 10 中的图像 1,1
    • The Lightning port.
  11. iPhone 6 Teardown: 步骤 11 中的图像 1,1
    • The Touch ID sensor.
  12. iPhone 6 Teardown: 步骤 12 中的图像 1,1
    • The front camera and proximity sensor flex cable.
  13. iPhone 6 Teardown: 步骤 13 中的图像 1,3 iPhone 6 Teardown: 步骤 13 中的图像 2,3 iPhone 6 Teardown: 步骤 13 中的图像 3,3
    • The iPhone 6 display assembly. It's thinner than the iPhone 5s/5c/5 screen.
    • The Touch ID Cable runs from the home switch to the top of the screen, adding a 4th connector at the top.
  14. iPhone 6 Teardown: 步骤 14 中的图像 1,3 iPhone 6 Teardown: 步骤 14 中的图像 2,3 iPhone 6 Teardown: 步骤 14 中的图像 3,3
    • After the usual painful desoldering of the shielding, we have the logic board in all its naked glory.
    • Analysis to follow with iFixit's full teardown.
    Somewhere in the teardown around the stage of the antenna area, this small piece came out and I don't know where from. Anyone know what this is?? It says, "00095-A" with a small box thing at the end of the character string. Thanks so much in advance!
    (showing both sides)
    [IMG]http://i61.tinypic.com/30augbc.jpg[/IMG]
    [IMG]http://i58.tinypic.com/2lld838.jpg[/IMG]
    [IMG]http://i60.tinypic.com/21k9kld.jpg[/IMG]
    shauhncy - 回复
    Any luck with finding the location of that small piece? Same thing happened here and I am trying to identify where it goes. My piece is same but with 1-00095-A 334 for the number. Thanks!
    Victor -
    its the antenna interconnect i believe..
    https://d3nevzfk7ii3be.cloudfront.net/ig...
    if that link doesn't work or you cant tell from looking where the part fits in then look at the iphone 6 power button tutorial which has all the steps to get to the part properly since it has to be removed to get to the power button.
    iPhone6电源键更换
    Hope that helps.
    ynit -
    I came across with the same piece with a mark 00095-A. I don't know where it came from. anyone knows about it?
    kpanmei95 - 回复
    antenna interconnect.. see above for links
    ynit -
    I have tried every possible location for that small piece with a character"00095-A" but found no place to fit in that piece. Maybe its just an extra part coz the phone itself is working fine. Anyone with better knowledge about it??????
    kpanmei95 - 回复
    its the antenna interconnect.. links posted in reply to original post
    ynit -
  15. iPhone 6 Teardown: 步骤 15 中的图像 1,3 iPhone 6 Teardown: 步骤 15 中的图像 2,3 iPhone 6 Teardown: 步骤 15 中的图像 3,3
    • More chip pics!
  16. iPhone 6 Teardown: 步骤 16 中的图像 1,3 iPhone 6 Teardown: 步骤 16 中的图像 2,3 iPhone 6 Teardown: 步骤 16 中的图像 3,3
    • Even more ICs.
  17. iPhone 6 Teardown: 步骤 17 中的图像 1,2 iPhone 6 Teardown: 步骤 17 中的图像 2,2
    • And that's all she wrote! We'll be back soon with a complete teardown and analysis from iFixit with higher resolution photos.
Patrick Lee
于09/19/13注册
2,605 声望
撰写一个指南
团队
iExperts iExperts 的会员
Business
1 名成员
创作了1篇指南
一条评论
I have 2 small pieces that fell out and I have no idea where they go. One has this code on it 1-00095A 344. And the other looks like a toggle switch, it is black. Can you help.
linda.lloyd - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 87,131
