简介
转到步骤 1 ↓这是 Apple iMac G3 M4984 型号的拆解。我觉得在开始之前也没什么好说的了。
你所需要的
2指南评论
yo what happened to this lmao
The last step was left off by the previous post. The last plastic piece to pull is tricky. Do not try and pry it off because there are literal hooks that link with the inner shroud. You CAN get it off with a little muscle once you understand how they hook inside. Here is a video from MOOT that explains. Basically, the trick is (with the iMac on it's bottom, CRT facing you), you must yank the sides upwards to unhook them. then you can work them out.
