跳转到主内容
Shark IC160 ICZ160 P50 Floor Nozzle Teardown
英语
中文
正翻译步骤 5
步骤 5
Shark IC160 ICZ160 P50 Floor Nozzle Teardown, Opening Stem cover: 步骤 0 中的图像 1,3 Shark IC160 ICZ160 P50 Floor Nozzle Teardown, Opening Stem cover: 步骤 0 中的图像 2,3 Shark IC160 ICZ160 P50 Floor Nozzle Teardown, Opening Stem cover: 步骤 0 中的图像 3,3
Opening Stem cover
  • The back of the Hoseguide has 2 TX10 screws that need to be removed.
  • The cover can the be unclipped starting from the tab at the bottom.
  • note the location of the ferrule around the white, yellow and black wire. It had to be all the way at the bottom for my cover to go back on.
  • I cut the wires below the ferrule and soldered new wires to the section going thru the hinge, your unit should have black white and yellow running all the way thru to the head.
在此插入翻译
在此插入翻译
在此插入翻译
在此插入翻译
您的所有投稿皆享有基于开源创作共享许可协议(CC BY-NC-SA)著作权利
