跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Xtorm XB304 Titan,请使用我们的维修手册
  1. Xtorm XB304 Titan Teardown, Xtorm XB304 Titan Teardown: 步骤 1 中的图像 1,3 Xtorm XB304 Titan Teardown, Xtorm XB304 Titan Teardown: 步骤 1 中的图像 2,3 Xtorm XB304 Titan Teardown, Xtorm XB304 Titan Teardown: 步骤 1 中的图像 3,3
    • The battery configuration seems to be 4S2P, with custom 18650 Li-Ion cells.
    • Two circuit boards are on the USB plug end, with large inductors inbetween, that are stuck in place with white silicon(?) glue.
    • The heat conducting grey foam has some sort of black heat spreader under it, with the thermocouple attached to that - the heat spreader seems to go below the (heat isolating?) white sticky foam that is over the battery part.
    • I didn't risk disassembling my power bank any further as I still need it - there seem to be phillips screws holding down the circuit board though.
  2. Xtorm XB304 Titan Teardown: 步骤 2 中的图像 1,3 Xtorm XB304 Titan Teardown: 步骤 2 中的图像 2,3 Xtorm XB304 Titan Teardown: 步骤 2 中的图像 3,3
    • The circuit board has the battery balancing circuitry directly on it, there isn't a seperate battery protection board.
    • The case seems to provide reasonable physical protection of the cells from sharb objects with double walls.
    • I didn't research any of the chips, they don't have the marking removed though.
ekalf
于03/28/21注册
85 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 33
总计 778
